My SS15
331 replies to this topic
#316 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted May 03, 2016 - 11:23 AM
Got it out of the barn today. https://www.youtube....eature=youtu.be
  • Sawdust said thank you
#317 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted May 10, 2016 - 08:46 AM
Tearing it down today going to sandblast it and paint it. I'm also going to find the running problem.
#318 John Arsenault OFFLINE
John Arsenault
  • 2,925 Thanks
  • 1,324 posts
Posted May 11, 2016 - 07:01 AM
From the video you posted above it seems like your on the right track...she runs!
What running problems are you having?
#319 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted May 11, 2016 - 02:51 PM
bogs down under load
#320 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted May 19, 2016 - 09:46 PM
At the tractor show they was thinking the ignition module was the cause so I was going to install the points back but the rod is broke.
My plan is to replace the ignition module and carb (I still got a feeling the carb is some of the issue). One of these day I will tear it down and replace the point rod.
#321 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted May 21, 2016 - 05:59 PM
I'm picking up SS15 #2 next weekend
#322 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,460 Thanks
  • 4,577 posts
Posted May 21, 2016 - 09:59 PM
Did you hear someone blowing their horn like a fool going by around 9:00 last night?
#323 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted May 22, 2016 - 08:58 AM
Nope
#324 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted May 25, 2016 - 09:08 PM
I had the same problem with my 16Hp briggs on my Mtd990. Very little spark due to a bent points pushrod. The bent rod messed my cam lobe up so instead of tearing a good running engine down I converted it to a Nova II electronic ignition module. Less than $15. & about 20 minutes to install...nice hot blue spark then. Check out my thread at post #60, 63, & 70. Hope this helps.
http://gardentractor...-mtd-990/page-4
  • bbuckler said thank you
#325 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted May 25, 2016 - 09:36 PM
I already have one on there and it has worked great but maybe the gas leaking on it ruined it. I still think it more of a carb issue just can't afford to replace it right now.
#326 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted June 12, 2016 - 10:10 PM
It was a leak around the intake that seemed to cause the bogging down it got plenty of power now
  • Alc, TAHOE and Sawdust have said thanks
#327 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted June 13, 2016 - 01:11 PM
I added a worklight to the back of it but I still need to wire it.
#328 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted June 26, 2016 - 11:22 PM
I used plastic dip paint on the foot rests and paint all the knobs. Pictures coming in the morning.
#329 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted June 27, 2016 - 09:25 AM
#330 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted August 21, 2016 - 09:59 PM
I got to start back on this headache again. It still bogs down really bad.
