My SS15
331 replies to this topic
#16 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted June 12, 2015 - 02:21 PM
Since I got to order a new solenoid so I guess I will go ahead and order another
#17 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted June 12, 2015 - 03:50 PM
You realize that the one you lost will show up the day after you order...
  • bbuckler said thank you
#18 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted June 12, 2015 - 03:54 PM
Yep it always does
#19 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted June 13, 2015 - 09:46 PM
Tomorrow me and my uncle is taking off the console and re wire it. Any tips on how to remove the steering wheel ?
#20 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,762 Thanks
  • 4,303 posts
Posted June 13, 2015 - 11:16 PM
Lots of PB blast and a puller. Be prepared to issue many @%$!% words. I have had "zero" luck with steering wheels and single axle rear tire rims.
  • rustyoldjunk and bbuckler have said thanks
#21 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted June 14, 2015 - 09:25 AM
I wished there was a easier way to get to the wires.
#22 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 283 Thanks
  • 229 posts
Posted June 14, 2015 - 11:10 PM
there is lol remove gas tank, battery tray and clutch assembly and bang you got access to wiring heres a link to my suburban 14 i am fixing and i got it back together and still not charging so getting me a new volt regulator sometime soon. for now though ill run her and charge battery between uses lol wont be but a couple weeks until i order one.
  • Sawdust and bbuckler have said thanks
#23 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted June 15, 2015 - 12:45 PM
I got the wiring finished I used a 3 post solenoid off a riding mower and it worked.
  • Sawdust said thank you
#24 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted June 15, 2015 - 03:02 PM
Found the linkage and got it running once again. There is a wire unhooked coming from around the flywheel anybody know whats it to and where it hooks up ?
#25 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted June 15, 2015 - 03:03 PM
#26 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,762 Thanks
  • 4,303 posts
Posted June 15, 2015 - 09:05 PM
Is it charging? 14+ volts at the battery?
#27 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted June 15, 2015 - 10:51 PM
I haven't checked yet I broke the governor control rod.
#28 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 283 Thanks
  • 229 posts
Posted June 15, 2015 - 11:50 PM
you want between 13-14.2v at battery when running nothing higher than 14.4 actually. my ss15 runs at 13.78vs at wot never have had a dead battery and it gets used at night with lights too.
#29 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted June 17, 2015 - 05:15 PM
I'm about to check the points and see if that why it been running rough
#30 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted June 17, 2015 - 08:03 PM
I didn't get to check the points but the charging system is working I guess it was the bad cable.
