My SS15
331 replies to this topic
#271 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 08, 2016 - 06:45 PM
Get the correct oil pan bolts, remember what I went through.
Since that was the smallest TSC had I guess I will install the old ones back.
#272 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted March 08, 2016 - 07:50 PM
Do you have an Ace Hardware near by?
#273 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 08, 2016 - 08:24 PM
Yeah. I put the old ones in for now I'm going to check it in the morning.
#274 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 08, 2016 - 08:41 PM
I kept having problems with the NOS Kit the vendor off ebay kept sending I think it the wrong needle.
Here a video of when I rebuilt it.
#275 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 08, 2016 - 10:20 PM
Check the oil when I went to feed the last bottle of the night and it good also the paper towel I laid down is dry.
#276 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted March 08, 2016 - 11:02 PM
Been there, done that. several times. You may be OK, until under load. just saying.
#277 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 08, 2016 - 11:05 PM
I think the old bolts will hold for now. The new bolts 1/4 was longer.
#278 KennyP ONLINE
  • 38,482 Thanks
  • 45,972 posts
Posted March 09, 2016 - 06:27 AM
I've been known to wack off the offending length!
#279 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 09, 2016 - 05:11 PM
The used solenoid I installed over the summer went bad while fight carb issues.
#280 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 09, 2016 - 05:37 PM
I'm thinking about buying another aftermarket carb to hold be over for a little while.
#281 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 11, 2016 - 06:13 PM
I guess when I pulled the dash up on the SS15 I knock a wire loose. I got it halfway out of the barn and started seeing smoke. I hope it just ruined the two wires and nothing else.
#282 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 12, 2016 - 01:29 PM
#283 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 13, 2016 - 08:11 PM
Since I broke the belt on my riding mower I decided to go ahead and buy the belts for the ss15.
#284 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 14, 2016 - 02:28 PM
I'm having governor issues on my SS15. Throttle down it shows 1200 rpms and 1000 rpms under a load. At full throttle is show 1700 rpms and 1300 rpms under a load. It as almost no pulling power right now.
#285 bbuckler ONLINE
bbuckler
  • 3,481 Thanks
  • 3,072 posts
Posted March 14, 2016 - 08:04 PM
Found it was leaking around the intake gasket. Found the threads on the cheap aftermarket is ruined so I tried tapping it no luck then I tried installing a helicoil and broke the carb. I rebuilt the one before rebuilding the engine but it pours gas out of it I check the float and everything it has to be the needle seat. I got a huge headache from working on it all day.
