My SS15
331 replies to this topic
#226 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted December 26, 2015 - 01:10 PM
It might need a new governor it idles fine and then I went and plowed a small patch it wouldn't get below at 1900 rpms at idle restarted and it back at 1200.
#227 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 07, 2016 - 01:18 PM
I thinking about selling my 2013 Craftsman LT2000 and buying a deck and the parts to finish the SS15. Also it would be one less thing to move.
#228 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted January 07, 2016 - 01:32 PM
Well, the SS/15 has more cool factor! Good luck!
  • bbuckler said thank you
#229 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 17, 2016 - 03:27 PM
I had a little bit of money left over so I bought a roll of gasket material. There was no gasket between the block and the intake manifold also but some fittings and bypass the fuel pump. Soon as I make some more money I need to order the parts from Doc to finish. I forgot to add it show 1300 rpms at full throttle and 995 at low throttle,
Edited by bbuckler, January 17, 2016 - 03:28 PM.
  • Bolens 1000 said thank you
#230 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 18, 2016 - 01:42 PM
Where is a good place to get tire tubes? I had bad luck with the Tractor Supply ones.
#231 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted January 18, 2016 - 01:55 PM
What brand is tsc using? The ones I have are CST brand and have only had one bad one out of all the ones I used and sold.
#232 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 18, 2016 - 01:59 PM
Traveller. Had two split in half while putting on the rims they seem to small to fit around rim. I order some in a past that went on without a fight.
#233 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 23, 2016 - 04:54 PM
Got blue smoke now under a load.
#234 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 23, 2016 - 08:36 PM
It will be a few weeks but the engine in going to get overhauled.
#235 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 26, 2016 - 04:05 PM
Pulled the motor off today. I really need a hoist my back would thank me.
#236 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 26, 2016 - 05:50 PM
#237 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 27, 2016 - 06:30 PM
Cylinder head got a small dent in like it got shot with a bb. Will be go ok to still use ?
#238 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted January 27, 2016 - 06:35 PM
I probably would! Is it above the piston?
#239 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 27, 2016 - 06:36 PM
Yes
#240 bbuckler ONLINE
bbuckler
  • 3,436 Thanks
  • 3,047 posts
Posted January 27, 2016 - 06:56 PM
Here in a photo of it
Edited by bbuckler, January 27, 2016 - 06:56 PM.
