My SS15
331 replies to this topic
#196 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted November 08, 2015 - 07:01 PM
Flooding like crazy and leaking around the bowl.
#197 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted November 11, 2015 - 06:48 PM
I'm thinking about bypassing the fuel pump I noticed today it leaking.
#198 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted November 11, 2015 - 07:41 PM
Won't run, gas tank is lower than the carb and gas doesn't flow up hill unless pumped.
#199 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted November 11, 2015 - 07:54 PM
The ss15 fuel tank sits about 3 inches higher then the carb
#200 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted November 27, 2015 - 05:03 PM
My Do List for the Sears SS15. First I want to rebuild the old carb and throw the aftermarket in the trash.
Briggs and Stratton Carb Kit
New Intake bolts
New Float
New Breather Tube
Bypass Fuel Pump
Find a Sears throttle lever
I hoping to start working back on it soon but I can't start this week to many Dr appointments .
I think this will finish the SS15 or at least I hope.
#201 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 03, 2015 - 04:55 AM
My carb on a Briggs 16 ate my lunch for a while , it all started with the choke shaft coming apart from the linkage arm and the choke staying on all the time ,  I cleaned the carb about 4 times by soaking it in a gallon can of carb cleaner and compressed  air , adjusted the float , polished the valve seat and it kept over flowing , it was horrible when I first took it apart , had green crystals which I think was ethanol gas that separated and pitting in the bowl , so I bought  and installed a kit for the carb , hard and soft parts and it still leaked , I have a brand new tank , fuel lines and filter so recontamination after cleaning  wasn't likely , I took the carb to the old guy at the lawn mower shop , he had the needle valve seat and the tool to install it , only charged me $10 to pull the old one and install the new one , it went for about 2 days and I came home from work and there was a puddle on the ground , at that point I had over $50 into the carb and a new one listed like $250 so I ordered an after market carb for $46 off ebay , it has been a couple of months and no problems ----was your after market carb new or used , I have bought a bunch of after market carbs over the years and have had good luck with them , is your tank clean , a speck of rust is all it would take to make it leak ----a trick the guy at the lawn mower shop showed me , that didn't work for me , was to take a drill bit the right size and lightly  by hand spin the bit in the needle seat back wards a couple of times , then use a Q-tip swob with some rubbing compound and polish the seat  -----or ----- when you say it is leaking around the bowl , could it be from the gasket between the bowl and the body , if so you may be able to use a piece of glass ( very flat ) or a table top would work and lay a sheet of fine sand paper over the flat surface and mill the bowl as it may be warped from uneven tightening
#202 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted December 03, 2015 - 12:46 PM
I found the float wasn't set right but the old is still going back on so I can have choke again.
#203 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 03, 2015 - 05:37 PM
 the choke was no problem on the after market carb , I drilled one small hole in the linkage arm of the carb for the wire to fit into
  • bbuckler said thank you
#204 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 03, 2015 - 05:47 PM
Here's a pic
  • Alc and bbuckler have said thanks
#205 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted December 12, 2015 - 04:04 PM
Anybody know what the rpm should be set at ? I got a new tachometer and want to try it out,
#206 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted December 12, 2015 - 05:00 PM
Can't get it below 2000 without cutting out
#207 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted December 12, 2015 - 05:19 PM
#208 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted December 12, 2015 - 07:33 PM
I have my twin set to ~2400 Idle and ~3530 for Governed. You don't want it to idle too slow, it will starve for oil. PS, the specifications for a single cylinder calls for 1500 idle, and a twin is 1750. I guess if you can't hit 1500, then there is still something not right.
#209 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted December 12, 2015 - 07:35 PM
They said at MTF that it sound like a air leak I'm going to order new gaskets.
#210 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted December 12, 2015 - 08:00 PM
Yes, bad gaskets would be an issue, I have had a loose throttle shaft in the carb cause rough idle also. It will let air in where it is not wanted.
