My SS15
331 replies to this topic
#166 bbuckler ONLINE
bbuckler
  • 2,666 Thanks
  • 2,394 posts
Posted September 21, 2015 - 10:50 AM
Weak spark now I'm going to check the points
#167 TAHOE ONLINE
TAHOE
  • 7,405 Thanks
  • 5,405 posts
Posted September 21, 2015 - 11:27 AM
Man, this thing is putting up a fight for ya.
I dealt with that on my 16/6. Fix one thing, then something else would go. I am fighting a charging issue right now. keeps burning up regulators.
  • bbuckler said thank you
#168 bbuckler ONLINE
bbuckler
  • 2,666 Thanks
  • 2,394 posts
Posted September 21, 2015 - 12:02 PM
I just started it and moved it this morning and then when back to move it again and nothing
#169 bbuckler ONLINE
bbuckler
  • 2,666 Thanks
  • 2,394 posts
Posted September 21, 2015 - 05:12 PM
it looks like I'm having a charging problem the flywheel wasnt spinning fast enough to start it
#170 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,156 Thanks
  • 3,931 posts
Posted September 21, 2015 - 08:23 PM
I don't think you are running it long enough between starts to re-charge the battery. I sometimes need to trickle charge mine, as I don't run them enough either. Do you have a multi-meter?
#171 bbuckler ONLINE
bbuckler
  • 2,666 Thanks
  • 2,394 posts
Posted September 21, 2015 - 08:29 PM
Got to borrow my uncles my dad took mine to work and it got stolen. I have been leaving on a float charger when it parked in the shed.
#172 bbuckler ONLINE
bbuckler
  • 2,666 Thanks
  • 2,394 posts
Posted September 22, 2015 - 03:08 PM
Going to put those turf tires on until after the show I'm running really low on cash.
#173 bbuckler ONLINE
bbuckler
  • 2,666 Thanks
  • 2,394 posts
Posted September 28, 2015 - 04:50 PM
Got one off but this one won't come off been trying for 2 days.
#174 bbuckler ONLINE
bbuckler
  • 2,666 Thanks
  • 2,394 posts
Posted September 30, 2015 - 07:47 PM
Got em on but can't get them to take air about ready to take to a tire shop
#175 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,156 Thanks
  • 3,931 posts
Posted September 30, 2015 - 07:52 PM
Grease the beads real well. Place a ratchet strap around the tire, remove the valve stem and use the air hose nozzle to shoot a lot of air in the tire, while rolling it back and forth.
#176 bbuckler ONLINE
bbuckler
  • 2,666 Thanks
  • 2,394 posts
Posted September 30, 2015 - 07:56 PM
Already done we are thinking the air compressor don't have enough psi
#177 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,156 Thanks
  • 3,931 posts
Posted September 30, 2015 - 08:01 PM
I have a 20 gallon compressor, it didn't have enough cfm's for the All-terrains I put on BMP, those had to go to a tire shop, and they had trouble too.
#178 MH81 ONLINE
  • 29,438 Thanks
  • 29,543 posts
Posted September 30, 2015 - 09:58 PM
Like Larry said, It's not the psi, it's the cfm that you can get thru the valve stem.
Increasing the psi will increase the cfm, but so will removing the core and running a bigger hose with fewer connectors.
I remember Dad hose clamping onto a stem and using a direct plumbed hose with a ball valve on one front tire on (i think) the Ferguson 35.
Got it to seat and then let it sit there a while with air. Eventually, he quick removed the hose and put in the stem core.
I think they are all tubed now.
#179 bbuckler ONLINE
bbuckler
  • 2,666 Thanks
  • 2,394 posts
Posted October 13, 2015 - 09:10 PM
I think I'm going to rebuild the engine before plowing this spring.
  • larrybl said thank you
#180 bbuckler ONLINE
bbuckler
  • 2,666 Thanks
  • 2,394 posts
Posted October 22, 2015 - 04:01 PM
I bought a 420 amp battery today and went to move trash half way down the driveway it started pouring the rain
