My SS15
331 replies to this topic
#136 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 06, 2015 - 04:35 PM
Other then the bowl leaking it feel like it has more power with the original carb .
#137 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 06, 2015 - 09:46 PM
It was smoking white smoke for a few seconds after starting it up today. Is it something I should worry about ? it didn't do it no more after the first time.
Edited by bbuckler, September 06, 2015 - 09:46 PM.
#138 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 07, 2015 - 12:12 PM
Installed the aftermarket carb back on the SS16 can't get the original carb to stop leaking even after I adjusted the float.
#139 MH81 OFFLINE
  • 29,979 Thanks
Posted September 07, 2015 - 01:04 PM
Yep, it's a Briggs
:poke:
Sorry, just wanted to lighten the mood.." Been there, done that."
  • bbuckler said thank you
#140 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 08, 2015 - 08:31 AM
It still blowing white smoke with I first start it but the oil level has changed any
#141 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,465 Thanks
  • 4,580 posts
Posted September 08, 2015 - 08:39 AM
Check to see if the breather filter is plugged up.
#142 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 08, 2015 - 08:45 AM
the breather tube has a hole in it can that be causing some of the problem
#143 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,465 Thanks
  • 4,580 posts
Posted September 08, 2015 - 09:50 AM
Not sure, I had a single cyl Briggs that would spew white smoke when making a hard right turn. if I remember correctly the reed valve under the breather housing had failed. I replaced the breather housing and the smoke issue went away.
#144 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 08, 2015 - 11:02 AM
no more smoke I have shut it off and on a lot today and haven't seen smoke anymore
#145 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 08, 2015 - 12:33 PM
#146 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 08, 2015 - 04:48 PM
Hooked up the cultivator for a photo. ImageUploadedByTapatalk1441748875.660088.jpg
#147 KennyP ONLINE
  • 40,942 Thanks
  • 47,128 posts
Posted September 08, 2015 - 07:01 PM
Hooked up the cultivator for a photo. attachicon.gifImageUploadedByTapatalk1441748875.660088.jpg
Wow! Black & White even!
#148 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 10, 2015 - 07:30 PM
One tire isn't holding air but I got a brand new tube in the shed.
#149 bbuckler ONLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 12, 2015 - 12:36 PM
It didn't take long for the paint to get messed up but it a working tractor I use it for everythingImageUploadedByTapatalk1442079379.499090.jpg
  • MH81, Alc and wvbuzzmaster have said thanks
#150 Alc ONLINE
  • 7,238 Thanks
  • 7,584 posts
Posted September 12, 2015 - 01:01 PM
Like you said " its a working tractor " that's how mine are . Can't be scared
  • MH81 and bbuckler have said thanks
