DB Cordwood Saw Up & Running
9 replies to this topic
#1 Alc OFFLINE
  • 6,744 Thanks
  • 7,397 posts
Posted June 11, 2015 - 05:20 AM
I've been rebuilding  the cordwood saw , weed cutter & brush cutter attachments that I picked up last month . The saw is the first one attached to the tractor The final piece was the clutch rod ,made one that's 1/2" stock instead of the correct 9/16" but it seems to work .  I tried it out last night and works well ,Did notice some of the set-screws for the pulleys loosened up . I'll go around the whole saw Here's the rebuild thread
http://gardentractor...wood-saw/page-1
Edited by Alc, June 11, 2015 - 05:42 AM.
  • Bolens 1000, daytime dave, MH81 and 14 others have said thanks
#2 MH81 OFFLINE
Posted June 11, 2015 - 06:35 AM
Wow, Al. That's really nice.
The rod should hold for all the more you're going to use it, maybe some lock tight on any bolts that might work loose?
Cutting brush with the chainsaw is a scary proposition, I'm glad you find this safer.
#3 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted June 11, 2015 - 06:48 AM
Nice job on a vary wicked looking machine.  Glad to see the massive OSHA approved guard on it anyway.
  • Alc and Bill 76 have said thanks
#4 KennyP ONLINE
  • 37,464 Thanks
  • 45,490 posts
Posted June 11, 2015 - 07:00 AM
Looks great. Are any of the set screws in far enough to put another on top of?
#5 Alc OFFLINE
  • 6,744 Thanks
  • 7,397 posts
Posted June 11, 2015 - 07:32 AM
Sorry I should have said " square head screws "   they used them instead of allen head set screws . Come to think of it some where a little longer and had jam nuts so maybe that was a " fix " at some point .
#6 KennyP ONLINE
  • 37,464 Thanks
  • 45,490 posts
Posted June 11, 2015 - 08:10 AM
I have seen those before and yes the jamb nut would help.
#7 OldBuzzard OFFLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted June 11, 2015 - 09:29 AM
:thumbs:  :thumbs: :thumbs:
I love attachments like that.
Ones guaranteed to give the Safety Nazis screaming nightmares  :D :D :D
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 11, 2015 - 09:49 AM
Oh boy have I been there and done that!! Those saws really work and work you.
Back in the 60s my dad used to haul off all the 4X4 and 2X4 blocking that was in railroad cars that were used in steel shipments to Maytag. We used a stationary belt driven saw powered by a B F Avery model A. What we did not burn was sold as firewood.
I never considered the saw to be as dangerous as the drive belt,far too many have died by getting tangled up in the belt.
Nice job Alc
Edited by JD DANNELS, June 11, 2015 - 09:50 AM.
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 29, 2015 - 01:00 PM
Used to have a saw like that mounted on one of our WD45's. What a work-out!
#10 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted July 09, 2015 - 05:10 PM
I have a Lowther C Saw like this. Mine has a ZZ Briggs and Stratton on it. I have had it running and sawed with it a long time ago
We like pictures
