Picked this Item Today!
36 replies to this topic
#31 KennyP ONLINE
  • 37,449 Thanks
  • 45,472 posts
Posted June 14, 2015 - 07:17 AM
I found this blade at Ace Hardware. With my Rewards card and Veteran discount, it was just over $13 with tax. I asked them if they would carry the 10-14 variable tooth blades as I read they last longer.
  • boyscout862, TomLGT195, Sawdust and 1 other said thanks
#32 KennyP ONLINE
  • 37,449 Thanks
  • 45,472 posts
Posted June 14, 2015 - 01:36 PM
Played with the saw some more. Got it to cut within 0.050" vertically on a 2-3/8" pipe. Think that's about as good as it will get.
  • olcowhand, boyscout862, TomLGT195 and 2 others have said thanks
#33 Jazz OFFLINE
Jazz
  • 2,302 Thanks
  • 1,403 posts
Posted June 16, 2015 - 02:47 PM
Nice saw and very versatile..I put a fine tooth blade on mine,,its slower for cutting plate steel and moose bones but then I don't have to be changing blades for cutting tube stock. I made a table for mine as I generally use saw in upright position
  • olcowhand, KennyP, boyscout862 and 2 others have said thanks
#34 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted June 17, 2015 - 12:05 AM
nice Band saw Machine  & set up
  • boyscout862 and TomLGT195 have said thanks
#35 KennyP ONLINE
  • 37,449 Thanks
  • 45,472 posts
Posted June 17, 2015 - 06:54 AM
That is a cool set up with it vertical. I think mine will do that now. I had to change out the 'stop' bolt for that as mine was bent and it wanted to nearly flop over, table and all. Since I have it on the roll around and ballast down below, I may be able to make that set up.
  • boyscout862, TomLGT195 and holdenboy1960 have said thanks
#36 Jazz OFFLINE
Jazz
  • 2,302 Thanks
  • 1,403 posts
Posted June 17, 2015 - 01:48 PM
I would suggest you make the "table" tilt.  I was in a hurry and did not get that fancy. We were cutting 1/2 steel plate that required a 30 degree angle on one side...a tilting table was required and it would not take much to alter my table at this time. For the angled cut i put a shim under base of table to adjust angle,,,not perfect but got the job done
  • KennyP and holdenboy1960 have said thanks
#37 KennyP ONLINE
  • 37,449 Thanks
  • 45,472 posts
Posted June 19, 2015 - 02:34 PM
I may see if I can incorporate this if I set it vertical.
It's off an old Delta saw I had. Might expand capabilities some.
I made a stop for making multiple cuts. Need to get some 1/2" rod for it to work on. Think if I get a 36" length and cut 12" off, I can use the short piece for shorter things. Then the 24" for longer items.
It is reversible, closest I can get it is 1-3/4". But that will help.
  • TomLGT195 and holdenboy1960 have said thanks
