Wiring
4 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 2,492 Thanks
  • 2,217 posts
Posted June 08, 2015 - 10:37 AM
I'm about to rewire my SS15 the battery cable end is falling off and since I have a bunch of new cables in my parts room I decided just to replace the whole cable but when I got to looking at the other wires the look like they been chewed on.
  • Traill95 said thank you
#2 boyscout862 ONLINE
  • 10,810 Thanks
  • 8,094 posts
Posted June 08, 2015 - 11:19 AM
Use liquid insulation to repair to insulation on the cables. It usually takes several coats. Good Luck, Rick
  • bbuckler said thank you
#3 MH81 ONLINE
  • 28,941 Thanks
  • 29,290 posts
Posted June 08, 2015 - 11:30 AM
I like heat shrink, but it's not easy to put on with connectors.
The liquid stuff is pretty good from the places I've seen it used, but like Rick said, it takes a few coats.
  • boyscout862 and bbuckler have said thanks
#4 bbuckler ONLINE
bbuckler
  • 2,492 Thanks
  • 2,217 posts
Posted June 08, 2015 - 11:55 AM
I have new connecters and wire I will probably replace the real bad ones and heat shrink the rest.
  • Sawdust said thank you
#5 Sawdust ONLINE
Sawdust
  • 4,942 Thanks
  • 3,019 posts
Posted June 08, 2015 - 08:35 PM
I don't know if it's the perfectionist in me or the satisfaction but rewiring for me is the way to go on a mess. My recent MTD 990 rebuild was the worst I've seen. It's not that expensive & it makes it easy to trouble shoot later on.
