briggs NPR6 on Bolens Huski walk behind
huski walk behind
8 replies to this topic
#1 chuszy OFFLINE
chuszy
  • 5 Thanks
  • 2 posts
Posted June 07, 2015 - 06:26 PM
Hi, my name is Chuck and I new to your forum, stumbled across looking for info on a Huski walk behind . I acquired a Huski GT a few years ago and was looking for information about these. I just dug it out of the barn to see if I can get it running it has a set of cultivators with it. Any information would certainly be appreciated. It has a Brigs and Stratton NPP6 engine with serial # 612987 and a model or series # 507006 are parts still available?  The serial # on the Huski is H10394 any info on this machine sure will helpful. thanks for your help
Chuck
  • Nato77, accidentalchild and laurarg3 have said thanks
#2 Bolens 1000 ONLINE
  • 15,423 Thanks
  • 18,280 posts
Posted June 07, 2015 - 07:01 PM
Hello , Welcome to GTT :wave:
Pictures will be a big help in determining what you have exactly. The early Bolens did not always have model numbers with them.
  • accidentalchild said thank you
#3 chieffan ONLINE
  • 11,343 Thanks
  • 7,106 posts
Hi Chuck and welcome to the forum.  Check the Manuals section for a manual for your tractor.  You can download 3 per day for free so go for it.  would love to see a picture of your tractor.  All the guys on here love pictures so when you get a chance post up a few.  Good luck getting your project up and running.
#4 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,111 Thanks
  • 10,183 posts
Posted June 07, 2015 - 07:18 PM
If you post a photo, I'll tell you if I like it. In any case, welcome to our place.
#5 DougT ONLINE
DougT
    Dog Approved
  • 7,112 Thanks
  • 5,077 posts
Posted June 07, 2015 - 07:57 PM
Welcome to the forum. The engine was built in April of 47. I'd put the tractor at 47 or 8 if the engine is original.
#6 LPBolens OFFLINE
LPBolens
  • 1,419 Thanks
  • 972 posts
Posted June 07, 2015 - 10:35 PM
Welcome to the GTTalk forums.
Is the engine maybe an NPR6 rather than an NPP6? The Bolens walk behinds from that era used a gear reducer mounted to the crank output of the engine, hence the "R6" part, which stands for a 6:1 gear reduction. If it is an NPR6, the tractor may be a model 12A, made from 1942-48.
Edited by LPBolens, June 08, 2015 - 09:21 PM.
#7 chuszy OFFLINE
chuszy
  • 5 Thanks
  • 2 posts
Posted June 08, 2015 - 01:21 PM
Wow thanks for all the replies, took another look it is NPR6 and has the gear reducer on it I'll try to attach picsIMG_0163.JPG IMG_0165.JPG
  • LPBolens and Nato77 have said thanks
#8 LPBolens OFFLINE
LPBolens
  • 1,419 Thanks
  • 972 posts
Posted June 08, 2015 - 09:24 PM
Look for an model # ID tag down where the handlebars attach to the main frame. It does look like someone has modified the front of the main frame.
#9 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted June 08, 2015 - 11:45 PM
What you have there is a model 12A. I'd say its a 47 but a couple more pics of it would help.
There are some parts still available for these engines, not everything but the common replaceable things like points, condenser and carb kits. You can find NOS Briggs parts for these.
Anymore questions just ask away, someone on here will help you out.
Also tagged with one or more of these keywords: huski, walk behind
