22 Hp Briggs Intek Starter
8 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted June 07, 2015 - 06:15 PM
The starter quit on my Poulan Pro, I tore it down and the brushes looked good, bottom bearing is good but the top bushing has a tiny bit of slack. I put it back together and it still drags.
Can you buy brushes and bushings and rebuild these?
  • laurarg3 said thank you
#2 KennyP OFFLINE
  • 29,395 Thanks
  • 40,390 posts
Posted June 07, 2015 - 06:58 PM
Sponsors might be able to find something for you.
#3 Bolens 1000 ONLINE
  • 12,887 Thanks
  • 17,285 posts
Posted June 07, 2015 - 07:04 PM
Do you have your starter's part number or engine model & code number, There is at least 1 brush kit available still for these types of starters.
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted June 07, 2015 - 08:26 PM
Yes I think so.
FamiLY YBSXS.7242VF NEXT LINE 040123YG69603
STAMPED ON THE STARTER MOUNTING PLATE 007 4
#5 Bolens 1000 ONLINE
  • 12,887 Thanks
  • 17,285 posts
Posted June 08, 2015 - 07:19 AM
The family info is for the government epa stuff
There should be a model and type or a model and code number stamped on the tops of the OHV covers or somewhere on the shroud.
  • Alc and JD DANNELS have said thanks
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted June 08, 2015 - 11:28 AM
Numbers on the valve cover Model 407577, Type 0284 E1, Code 040123Y6
#7 Bolens 1000 ONLINE
  • 12,887 Thanks
  • 17,285 posts
Posted June 08, 2015 - 11:38 AM
That works
Brush kit runs $19.95
Do the bushings  look like the picture below? Your particular starter does not show individual bushings available
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted June 08, 2015 - 05:52 PM
I think so on the bearings. I will keep you in mind. I have two of these engines and would like to rebuild one to keep on hand.
I bought a used starter today and ran it about 10 minutes and it started popping back through the carburator.
I pulled the valve covers and found two bent pushrods.
Will have to pick up a couple tomorrow..
#9 Bolens 1000 ONLINE
  • 12,887 Thanks
  • 17,285 posts
Posted June 08, 2015 - 05:57 PM
Glad I could help
Starters for these new are not too bad in price either $74.95 Shipped
  • JD DANNELS said thank you
