Ford LGT 145 Field Find
46 replies to this topic
#31 ToddQ OFFLINE
ToddQ
  • 30 Thanks
  • 26 posts
Posted June 22, 2015 - 08:40 AM
KennyP! Thanks for that pic! That will be really helpful!
Could you also get a pic a little closer up of the switches!
Thanks again!
Oh, and my starter solenoid is on the inside of that panel, not the outside... I wonder what "factory correct" is.
Edited by ToddQ, June 22, 2015 - 12:06 PM.
#32 KennyP ONLINE
  • 41,506 Thanks
  • 47,420 posts
Posted June 22, 2015 - 09:54 AM
Not sure if you can see much around the switches, but I'll get a shot. My solenoid was outside when I got the tractor. Inside would be in the way if you added the second hydraulic valve. Plus, easier to work on out there!
  • ToddQ said thank you
#33 KennyP ONLINE
  • 41,506 Thanks
  • 47,420 posts
Posted June 22, 2015 - 10:49 AM
Here's a pic of the mess behind my dash!
#34 Sprint 6 OFFLINE
Sprint 6
  • 256 Thanks
  • 311 posts
Posted June 22, 2015 - 12:22 PM
The solenoid should be on the outside and accessible, AFAIK.  My closed side LGT165 is like that and so was my closed side LGT145 parts machine.
#35 ToddQ OFFLINE
ToddQ
  • 30 Thanks
  • 26 posts
Posted June 22, 2015 - 12:39 PM
Thanks again KennyP and Sprint 6! I'll move my solenoid outside - will make it easier to work on.
Next bit I need help on - what size fuses do I use? I show a 30 amp fuse for the orange wire going to the stator. But I can't find the rating for the one for the headlights (red wire) or the seat switch (blue wire).
Edited by ToddQ, June 22, 2015 - 02:58 PM.
#36 KennyP ONLINE
  • 41,506 Thanks
  • 47,420 posts
Posted June 22, 2015 - 02:11 PM
I'm not sure what is in mine!
#37 FixItCharlie OFFLINE
FixItCharlie
  • 581 Thanks
  • 366 posts
Posted June 22, 2015 - 08:27 PM
This may help
Charlie
  • Alc and ToddQ have said thanks
#38 ToddQ OFFLINE
ToddQ
  • 30 Thanks
  • 26 posts
Posted June 23, 2015 - 12:11 PM
This may help
Charlie
Thanks Charlie, but I already have a diagram. I need some close-up pics of the back of the Ignition and PTO switch to show which wires connected where.
#39 KennyP ONLINE
  • 41,506 Thanks
  • 47,420 posts
Posted June 23, 2015 - 12:20 PM
Maybe a color coded diagram would work better. I can't get any closer as there is no room. This shows the same as a picture would.
#40 ToddQ OFFLINE
ToddQ
  • 30 Thanks
  • 26 posts
Posted June 23, 2015 - 02:29 PM
If the wires are in the same position on the backside of the switches, that should work. Thanks! :)
#41 FixItCharlie OFFLINE
FixItCharlie
  • 581 Thanks
  • 366 posts
Posted June 23, 2015 - 04:20 PM
The diagram I sent shows the size of the fuse that you were asking about.
Charlie
#42 ToddQ OFFLINE
ToddQ
  • 30 Thanks
  • 26 posts
Posted June 24, 2015 - 06:53 AM
Charlie
Dude! I didn't even catch that! Thanks a lot - that works perfectly!
#43 tater195 OFFLINE
tater195
  • 2,288 Thanks
  • 1,455 posts
Posted June 25, 2015 - 03:24 PM
dude you gotta change that avatar pic. Sometimes I surf GTT while I am eating lunch
  • Alc, KennyP, Rock farmer and 1 other said thanks
#44 ToddQ OFFLINE
ToddQ
  • 30 Thanks
  • 26 posts
Posted June 26, 2015 - 06:57 AM
Sorry about that! I forgot my Facebook profile pic is linked here. Won't do it again! :)
#45 TomLGT195 OFFLINE
TomLGT195
  • 4,102 Thanks
  • 2,930 posts
Posted June 26, 2015 - 04:41 PM
Hey, a pic with clothes!!  :thumbs:  :thumbs:
Todd we're just busting on you. Tom
Good luck with the Ford!
Edited by TomLGT195, June 26, 2015 - 04:42 PM.
