Low Retaining Wall Replacement
13 replies to this topic
#1 grnspot110 ONLINE
grnspot110
  • 4,162 Thanks
  • 2,649 posts
Posted June 07, 2015 - 07:38 AM
We have a low (14-16") retaining wall along the back of the drive that I put in 25+ years ago with a row of RR ties & two rows of landscape timbers.  It's rotting out, so it's time for replacement:  HPIM1702.JPG
Due to the quality of current ties & timbers, I'm replacing with concrete retaining wall blocks.  Not sure yet if I'll need two or three layers, I'll dig some of the old ones up today to see how many I need.  I've brought 60 blocks so far for the 38' wall.  HPIM1701.JPG
The blocks are on sale right now at Menard's & I'll be there twice this week, so I'll pick up more blocks then.
  • Gtractor, KennyP, tinbender7 and 7 others have said thanks
#2 MH81 OFFLINE
Posted June 07, 2015 - 07:47 AM
I have a wall to build at some point too.
I'll be watching.
  • tinbender7 said thank you
#3 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted June 07, 2015 - 08:15 AM
Those make a nice looking wall. Be sure they are sitting on solid ground and pretty level to start.
  • tinbender7, boyscout862 and Sawdust have said thanks
#4 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted June 07, 2015 - 09:27 AM
I'll be watching.
Ditto
#5 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted June 07, 2015 - 09:52 AM
The two most important things are a good base to build on and the backfill must be free draining. Kenny is right. The base must be solid and not frost susceptible. For ease and speed of construction it must be compact and level. When the wall is up, line the back of it with filter fabric and backfill with freedraining material such as a clean sand. The freedraining material should be less susceptible to frost heave. Good Luck, Rick
  • TomLGT195 said thank you
#6 grnspot110 ONLINE
grnspot110
  • 4,162 Thanks
  • 2,649 posts
Posted June 07, 2015 - 11:55 AM
I'm only going to have to use two layers & the top layer will be from ground level up.  So all I really have to worry about is a solid, level base.  My main tools are a sturdy trowel, rubber dead-blow mallet & torpedo level.
  • KennyP, boyscout862 and TomLGT195 have said thanks
#7 TAHOE ONLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted June 09, 2015 - 08:39 AM
I need to do the same thing, but mine needs to be about 2'- 2 1/2' tall to prevent dirt from coming over, gravel driveway keeps getting mud piles on it. I can't afford much of anything to do it right now, I want to do railroad ties.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 11, 2015 - 10:34 AM
Those retaining walls made with those blocks are nice.
There was a house I used to walk by every day on the way to school in elemetary.
It had a retaining wall made of paving brick from the streets when paved that was about 6 ft high.
A couple years ago a guy bought that hilly place and terraced it, put in a garage and parking area and did all the retaining walls with those blocks. I would guess he had well over 1000 blocks in that project?
#9 grnspot110 ONLINE
grnspot110
  • 4,162 Thanks
  • 2,649 posts
Posted June 11, 2015 - 11:27 AM
Got all the blocks I need, about $180 for a 38', two block high wall.  Put some in, but it may be a while before it's finished!
  • Alc, KennyP, TAHOE and 2 others have said thanks
#10 olcowhand ONLINE
  • 41,261 Thanks
  • 31,447 posts
Posted June 11, 2015 - 05:03 PM
I have a flower bed retaining wall rotten I need to replace this fall. Going with similar stone.
  • grnspot110 and Sawdust have said thanks
#11 alleyyooper OFFLINE
alleyyooper
  • 939 Thanks
  • 419 posts
Posted June 14, 2015 - 08:32 AM
When I was a kid a fellow my dad worked for part time doing custom farm work had a retaining wall about 5' high over a 100' long all from field stone. I still remember how nice that looked with lawn in front of it and above behind it.
Wish I knew how to lay field stone like that. I would build one here.
:D   Al
#12 The Fife Plooman OFFLINE
The Fife Plooman
  • 1,629 Thanks
  • 305 posts
Posted July 13, 2015 - 08:39 AM
Hi GRNSPOT110
If and when you start your wall dig out base  for concrete 3 inches should be enough unless you intend building wall higher at a later date make sure the top of the concrete finishes i inch below ground so that your first  row of bricks  starts i inch below ground level this gives you a neat finish and looks good
every so often put a piece of 2 inch pipe through the wall to let the water run out behind the wall hope you can follow my hints
George S
#13 JBRamsey ONLINE
JBRamsey
  • 1,474 Thanks
  • 841 posts
Posted September 07, 2015 - 01:17 AM
I built a wall early this year from random stones. Most came from my yard. Others I picked up during travels here and there. If I saw a good looking rock I would grab it. I did cheat and buy a pallet of stone for the capstones. I haven't finished the cap yet, but it turned out ok considering I have neither skills or talent.image.jpg image.jpg image.jpg
  • olcowhand, grnspot110, KennyP and 1 other said thanks
#14 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted September 07, 2015 - 05:52 AM
Looks good!
  • JBRamsey said thank you
