A few years ago my Dad had replaced the 8 hp Briggs on my Panzer with another that was on a Kemp Chipper because it had low hours,,,now i always remembered that had a set throttle when it was on the chipper,,, I have never been able to get thiis to run right,,, the carb is new last year and clean, he used all the carb linkage and what not off the the original engine,,, my questioin is did the engine with set throotle have a different governor? Or did he use the wrong rod from the carb to the governor ?
Briggs carb and governor question
#1
OFFLINE
Posted June 05, 2015 - 05:10 PM
- classic said thank you
#2
OFFLINE
Posted June 05, 2015 - 05:19 PM
- Lmiller3358 said thank you
#3
OFFLINE
Posted June 05, 2015 - 05:35 PM
#4
OFFLINE
Posted June 05, 2015 - 06:54 PM
I'll have to double check the model # Classic,,,I'll see if i can get pic of the governor area tomorrow also
#5
OFFLINE
Posted June 05, 2015 - 07:06 PM
#6
OFFLINE
Posted June 05, 2015 - 07:36 PM
This is one of my "rules of thumb" on setting a governor. It will apply to about anything you work on and at least get you in the ball park. With the engine not running and the gov rod removed, move both the throttle and gov rod to its WOT stop. That's the distance you need between the two. I would make the rod fit beween the two at that setting. If the arm is adjustable on the shaft, you need to mak sure the shaft is abe to bottom to the gov. I check this measurement against the one at closed throttle for the gov and carb. sometimes its a crap shoot whether you move the arm on the shaft or change the rod. Whatever you do, you want to make sure that the gov lever is bottomed against the gov when the throttle plate hits WOT. If you are moving the arm on the shaft, make sure you have a hold of the shaft and make sure its turned all the way against the gove before you tighten the arm to it.The rest will be working with the external spring tension to fine tune it to do what you want.
- Lmiller3358 and propane1 have said thanks
#7
OFFLINE
#8
OFFLINE
#9
OFFLINE
Posted June 06, 2015 - 06:14 PM
20150606_144407.jpegOk, unable to find the model number right now, but I took a pic of where the governor is when at idle
If you pull the arm down you go to wide open throttle? Unhook the spring between the cable bracket and the arm. Loosen the arm from the shaft and pull the arm down and make sure you can get all the way open at the throttle. Then use a screwdriver in the shaft and turn it all the way clockwise until it bottoms. hold it all in position and tighten the arm to the shaft. That should be the first step to setting the governor.
- Lmiller3358 and classic have said thanks
#10
OFFLINE
#11
OFFLINE
Posted June 07, 2015 - 07:16 AM
Thanks, I'll try that today Doug
