First time with a tractor, JD 265 manual lift stuck
14 replies to this topic
#1 Mpatters0n OFFLINE
Mpatters0n
  • 4 Thanks
  • 3 posts
Posted June 04, 2015 - 08:41 PM
Hi everyone,
I'm brand new to the forum and brand new to tractor ownership thanks to an auction I went to last night.
Anyhow, I brought my tractor home tonight and it runs great but it seems like the manual lift is either stuck or seized. Like I said I'm complete new to this stuff but it would seem to me that the lever should move. (And yes I pushed the button first:))
If this helps it does have a 48" deck with it but I don't have the year.
Thanks!
  • larisaPn said thank you
#2 MH81 OFFLINE
Posted June 04, 2015 - 09:34 PM
Sorry it took an hour to get your 1st post up.
Welcome to GTtalk, do you have a pic of your new GT?
  • Lmiller3358 said thank you
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,108 posts
Posted June 04, 2015 - 09:57 PM
Couple of things with the manual lift. Make sure the height adjustment knob works correctly. It might cranked all the way, not allowing the deck to move. Linkages on the lever may be gummed or froze up. Or the lift adjustment may be unhooked or broke.
#4 jimbobbillyray ONLINE
jimbobbillyray
  • 3,064 Thanks
  • 2,892 posts
Posted June 04, 2015 - 11:15 PM
Hello and welcome to GTtalk! Great bunch of folks here.
I think that CAT385B has it right....the deck height is set all the way up for a high cut or something along this line is the problem
#5 KennyP ONLINE
  • 40,126 Thanks
  • 46,764 posts
Posted June 05, 2015 - 05:41 AM
:wave: Welcome to the forum! Pics can help at times to remedy an issue, so check out the link in my signature.
#6 DennyIN OFFLINE
DennyIN
  • 345 Thanks
  • 210 posts
Posted June 05, 2015 - 06:29 AM
With the deck handle on the right all the way up, you can lift and rotate the knob in front of the seat, which clockwise will make the deck higher, and ccwise will let the deck down farther (if my remember is working right). There are arrows on that know that show which way to go. Sometimes a little oil on the threads of the adjust knob in front of the seat will let it operate easier, but raise the deck up all the way before making the adjustments. After making the adjustment, push the release button and let the deck down to the adjusted height. As an FYI, you can lock the deck down and it won't float if you push the raise handle on the right, all the way down. To release it from that position, push/force it down, push the button in and hold it, then raise the handle, it will/should be against some spring tension when doing that.
#7 Mpatters0n OFFLINE
Mpatters0n
  • 4 Thanks
  • 3 posts
Posted June 05, 2015 - 06:33 AM
Wow! I wasn't expecting this many replies this quickly! I'll post some pictures tonight if I have an opportunity to take some after work tonight.
Thanks Cat385B. I never thought to check the height adjustment knob, thanks again! I'll check that tonight too.
#8 Lmiller3358 OFFLINE
Lmiller3358
  • 1,530 Thanks
  • 1,447 posts
Posted June 05, 2015 - 02:04 PM
Welcome aboard, If you have questionss, these guys will give you an answer,,,you picked the right place to come to ! enjoy
#9 Trav1s OFFLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 05, 2015 - 03:45 PM
Here is a pic of the lift assembly from JDParts.  It might help figure out what is the problem
  • Jeremy37 said thank you
#10 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted June 05, 2015 - 05:32 PM
It is a spring loaded mechanism.....you may have to really push it.
#11 hdg4400 OFFLINE
hdg4400
  • 286 Thanks
  • 351 posts
Posted June 05, 2015 - 09:04 PM
Mpatters0n:
Welcome to GTTalk. Check your Personal Messages. I have something that might be of interest to you.
Harlan
  • Trav1s said thank you
#12 Mpatters0n OFFLINE
Mpatters0n
  • 4 Thanks
  • 3 posts
Posted June 10, 2015 - 04:10 PM
Thanks again everyone. I have a solution. There is a step that I missed - after pushing the button in I had to push the lever down then pull up. I was pushing the button and reefing up on the lever like a caveman.
As a side note I took it out for her maiden voyage and not only a great ride but a great cut and with a 48" deck I was done in no time.
  • KennyP and Trav1s have said thanks
#13 Trav1s OFFLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 10, 2015 - 08:58 PM
:thumbs:  :thumbs:  :thumbs:  :thumbs:
#14 KennyP ONLINE
  • 40,126 Thanks
  • 46,764 posts
Posted June 11, 2015 - 05:11 AM
Glad you got it figured out!
#15 Jeremy37 OFFLINE
Jeremy37
  • 1 posts
Posted October 23, 2017 - 07:31 PM
Hi everyone, New to the forum here. Question on the lift handle,I replaced my hydrostatic drive belt upon completion my lift handle dont work, thought maybe I'm missing a spring but I only removed the 2 bolts from the bottom of the handle(while in the up position) to remove the seat entirely. #5 on the diagram from Trav1s sits behind the plate and the plate moves freely. #17 catches on #34 but with no resistance to lift or drop the handle, any guidance is greatly appreciated.
