WOW, There Is A Hydro In There.
12 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,887 Thanks
  • 15,514 posts
Posted June 03, 2015 - 12:53 PM
I've got an old JD 300 that had a broke rod in it and I also have a JD 216 with rearend issues. I decided to take the good running K341 out of the 216 and install it in the 300 so I have another mowing tractor for the year. I needed to pull the fender pan to get the tank off to clean it and I also thought I would pressure wash the whole tractor while the engine is out and tank/seat pan off. I couldn't believe how much dirt and crud was on this hydro. There was so much dirt on the top of the hydro that the relief valves wouldn't push down to let the tractor free wheel.
               Before
            After a bath..
  • Alc, hamman, KennyP and 7 others have said thanks
#2 MH81 OFFLINE
  • 29,978 Thanks
Posted June 03, 2015 - 01:00 PM
Yuck, that's nasty.
Bet it works better now
  • Texas Deere and Horse and boyscout862 have said thanks
#3 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted June 03, 2015 - 01:09 PM
Wow, worse than the mental picture you gave me on the phone!  But have a question for you.  On my oldest John Deere F935, it has the same basic hydro system, and I've had it quit on me a couple times, and had to pull it in.  I push the buttons down, but can only go 10 feet or less and the buttons pop back up & I drag the drive wheels.  I thought the buttons are supposed to stay down until the hydro is running again??
  • 14,887 Thanks
  • 15,514 posts
Posted June 03, 2015 - 01:15 PM
They should have something hold them down as they are spring loaded and will come back up on their own with no help. If they are sticking down from rust and dirt, the hydro will build enough pressure when running to pop them back up.
#5 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted June 03, 2015 - 02:51 PM
Neither of my 935's have any provision for holding the buttons down.  I really need to fashion a clamp on tool of some sort to do just that. The only times I've had issue was when the engine isolator rubbers came apart so the drive shaft disconnected..
  • Texas Deere and Horse and KennyP have said thanks
#6 Leonard VanCamp ONLINE
Leonard VanCamp
  • 658 Thanks
  • 473 posts
Posted June 03, 2015 - 04:16 PM
Olcowhand, on the 140 and 300 series tractors that have this hydro there is a hole in the fender deck with a threaded nut welded to it. A threaded rod with a knob on one end and a cross bar on the other is run through this hole and nut to push against the buttons, maybe you could come up with a similar system.
Edited by Leonard VanCamp, June 03, 2015 - 04:16 PM.
  • Texas Deere and Horse and Trav1s have said thanks
#7 TomLGT195 OFFLINE
TomLGT195
  • 4,047 Thanks
  • 2,899 posts
Posted June 03, 2015 - 05:13 PM
That was certainly dirty. It should run a lot cooler now.
#8 KennyP OFFLINE
  • 40,880 Thanks
  • 47,091 posts
Posted June 03, 2015 - 05:19 PM
Are you sure Daniel didn't use this out in the cow pasture?
#9 Trav1s ONLINE
Trav1s
  • 3,574 Thanks
  • 4,547 posts
Posted June 03, 2015 - 05:39 PM
Both the 120 and the 314 I had for a while were like that.  The 312 was not so bad.
#10 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 03, 2015 - 07:47 PM
Pretty filthy Brian! Did you get it running in the end? On my 317, one of those valves was sticking down. They are huge bucks from JD but somewhere I read that they are available from Sundstrand dealers for like 50$ each. I know where there is a 300 sitting outside with a broken steering wheel and no seat. I 'm going to knock on the door one of these days to see if they want to sell it. Good spare parts for my 314 and 317. If the engine is good I'd probably swap it into the 314.
#11 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted June 03, 2015 - 10:54 PM
And here I thought the one on the JB I bought was dirty!!! Looks a lot better now :thumbs:
#12 Cvans ONLINE
  • 7,282 Thanks
  • 6,376 posts
Posted June 03, 2015 - 11:29 PM
Brian have you been dredging the river bottoms again? That was ugly.
#13 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted June 04, 2015 - 07:47 AM
This thread reminds me i need to pull the pan on my 300, it doesn't freewheel.  hope it's something on the outside like texasdeerehorse tractor.
there is a guy on ebay rebuilds sunstrand valves if need be
http://www.ebay.com/...=STRK:MEBIDX:IT
i have no connection just putting it out there,
