Carburetor rebuild kit
#1
OFFLINE
Posted June 02, 2015 - 12:56 PM
Tom
#2
ONLINE
Posted June 02, 2015 - 01:10 PM
Hello,
Sounds like your seat is not functioning properly or you have a hole in your float
If your carb is correct it should take this kit
https://bolenspartsa...or-rebuild-kit/
The LQ33 is also the correct kit and has a little better Needle valve that is spring loaded, those are $ 1.50 more
If you have more questions or want the LQ33 send me a PM or email me through the site , before spending money on a kit I would check the float and float setting and see if that helps, of course if you have the old style metal needle I would get a kit, the new ones have a viton rubber tip for better sealing.
- boyscout862 and superaben have said thanks
#3
OFFLINE
Posted June 04, 2015 - 11:21 PM
#4
OFFLINE
Posted June 04, 2015 - 11:35 PM
Where can I get a manual for this carburetor? I can't seem to locate one in the manuals section.
Scroll almost all the way to the end.
http://gardentractor...-repair-manual/
#5
OFFLINE
Posted June 05, 2015 - 12:19 PM
