Where to buy Ford LGT125 replacement gas tank?
lgt125 gas tank
6 replies to this topic
#1 ruthconsulting OFFLINE
ruthconsulting
  • 1 Thanks
  • 1 posts
Posted June 01, 2015 - 10:02 PM
The gas tank on my Ford LGT125 developed some interior rust on the bottom of the tank which has perforated thru. I searched online without success for a parts source to buy a new or used one, under both Ford and Jacobsen. I found other model's gas tanks but not mine. Does anyone know of a good source for parts? I did a makeshift repair with JB weld tow part epoxy but I would not expect it to last forever. When I wire brushed the tank to prep it for the sealer my one pinhole leak became 7 pinholes.
Rick
  • tinbender7 said thank you
#2 TomLGT195 OFFLINE
TomLGT195
  • 4,051 Thanks
  • 2,900 posts
Posted June 02, 2015 - 04:23 AM
:welcometogttalk: & :wewantpics:   Is this an open side model?   Someone should be along with more info. Did you check our site sponsors ? Tom
  • tinbender7 and boyscout862 have said thanks
#3 KennyP ONLINE
  • 40,901 Thanks
  • 47,101 posts
Posted June 02, 2015 - 05:13 AM
:wave: Welcome to the forum! Like Tom said above, knowing which LGT125 it is can make a big difference. But, since you say it's metal, I think you have the open side. I would check with the site sponsors as well. Pics do a lot of explaining, so check the link in my signature below for help with those.
#4 Alc ONLINE
  • 7,226 Thanks
  • 7,579 posts
Posted June 02, 2015 - 05:16 AM
Welcome to GTTalk !!  , There are some posts about repairing rusty fuel tanks if you can't find one
#5 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted June 02, 2015 - 08:02 AM
try our site sponsors , I bought one for my LGT 165 from one of them.
#6 case1man OFFLINE
case1man
  • 204 Thanks
  • 142 posts
Posted June 02, 2015 - 08:57 AM
I have used tanks off cub cadets with good luck ,seem to be easier to find
#7 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted June 04, 2015 - 06:56 PM
cub cadet wide frame models 108,109 128 129 149 all those tanks will fit a open side ford
Also tagged with one or more of these keywords: lgt125, gas tank
