Belarus 2045, need engine parts
3 replies to this topic
#1 Oldhorse53 OFFLINE
Oldhorse53
  • 1 Thanks
  • 2 posts
Posted June 01, 2015 - 09:18 PM
I have a 2045 Belarus with a rod bearing gone, possible shaft damage, it has a 22 HP 2 cyl DSL engine . Any info on parts or complete engine would be appreciated.
  • prosparky said thank you
#2 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,661 Thanks
  • 5,049 posts
Posted June 01, 2015 - 10:40 PM
:welcometogttalk:
If you are close enough to Chillicothe,  talk to John or Rob at Carquest machine shop.  Around back of Carquest Auto Parts store on the main drag.
They can build up journals on the crankshaft and smooth it back to stock size and should be able to find an insert the right size to make something work.   They might even find a thicker insert and turn the crank down one size which would be cheaper.
Best of Luck!
#3 Oldhorse53 OFFLINE
Oldhorse53
  • 1 Thanks
  • 2 posts
Posted June 02, 2015 - 03:33 AM
Thanks for the info TNC, I am in Trenton, so will make a call to the Chillicothe Carquest tomorrow. I would rather rebuild this engine than try to repower and have to adapt another engine. How far are you from the 'Funny Farm' ?
#4 Gtractor OFFLINE
Gtractor
  • 9,661 Thanks
  • 5,049 posts
Posted June 02, 2015 - 05:22 AM
I'm 8 miles south of Chillicothe.
Ask for John in the machine shop.  He usually likes a challenge.  He has come up with some fixes that not many could/would do.
