Repower Simplicity 9020
onan performer 24 xls rebuilding an onan 19.5 ccbk
11 replies to this topic
#1 cey146 OFFLINE
cey146
  • 4 Thanks
  • 16 posts
Posted June 01, 2015 - 01:01 PM
I have an Onan CCBK 19.5 h.p. in the 9020, currently. Needing to know if an Onan Performer 24XLS will fit, bolt up, and well......perform.
Appreciate any and all the help I can get.
Thanks.
#2 cey146 OFFLINE
cey146
  • 4 Thanks
  • 16 posts
Posted June 02, 2015 - 03:00 PM
Above model number should be 24XSL.
It's a P224G-I engine.
Please help if you can.
THANKS.
#3 KennyP OFFLINE
  • 37,526 Thanks
  • 45,518 posts
Posted June 03, 2015 - 06:00 AM
I don't know the CCBK Onans very well. I have a P220 engine and it is sweet. I think the P224 would be very similar as far as fit goes. Not sure, though.
You'll gain some power, but may lose some MPG.
#4 cey146 OFFLINE
cey146
  • 4 Thanks
  • 16 posts
Posted June 03, 2015 - 06:59 AM
Thanks KP for your input.
any others gave more to add?
I have the CCBK pulled, and setting on the floor. Noticed right away the mounting pattern is different from the P224. That's an easy fix. The exhaust could be a problem, still need to remove it to see if it will remount on the P224.
Currently having some issues with the P224 losing spark, and working toward finding that problem, before going any further with the repower effort.
#5 KennyP OFFLINE
  • 37,526 Thanks
  • 45,518 posts
Posted June 03, 2015 - 07:32 AM
Here's a link to the P224 Service Manual. One other thing to check is the crank center height. Plus overall size compared to the CCBK. Are the PTO side of the cranks the same diameter? Was anything attached to the flywheel end of the CCBK? If so, will that still attach to the P224?
Good luck! Wish I had a P224.
#6 cey146 OFFLINE
cey146
  • 4 Thanks
  • 16 posts
Posted June 03, 2015 - 07:37 AM
Kenny, I stumbled on to this 224 at an auction. It is mounted in a Pow'r Gard generator, and it all sets on a to towable trailer. It had been used at an airport, and the hour meter shows just 79 hours.
I took a chance that it might fit in my Simplicity 9020. Hoping for the best.
#7 cey146 OFFLINE
cey146
  • 4 Thanks
  • 16 posts
Posted July 10, 2015 - 10:23 PM
The 224 will not fit, I'm going to have to look for a buyer for it. Where would be my best place to advertise the P224G-I, in order to get the best price for the engine?
I also am testing the waters for an interested person to purchase the CCKB.
Thanks to all for your help.
#8 KennyP OFFLINE
  • 37,526 Thanks
  • 45,518 posts
Posted July 11, 2015 - 05:58 AM
What's the issue with the fit?
#9 cey146 OFFLINE
cey146
  • 4 Thanks
  • 16 posts
Posted July 11, 2015 - 07:26 AM
Kenny,
It actually was a combination of things. Length, width, and height. Once we got the generator separated from the engine, it was discovered that it has a tapered shaft. So, the entire deal went south on me.
#10 cey146 OFFLINE
cey146
  • 4 Thanks
  • 16 posts
Posted July 21, 2015 - 10:19 PM
Does anyone have a suggestion as to where I might want to advertise the Onan P224G-I engine?
Thanks for your input.
#11 KennyP OFFLINE
  • 37,526 Thanks
  • 45,518 posts
Posted July 22, 2015 - 05:58 AM
Do you still have the generator for it? If so, put it back together and sell on CL.
#12 cey146 OFFLINE
cey146
  • 4 Thanks
  • 16 posts
Posted July 22, 2015 - 07:57 AM
KP, The generator has burnt windings in the Exciter. Had an estimate of $2000 to repair it. I need to sell the engine, so I can buy one for the Simplicity 9020.
I also will sell the original out of same tractor. Where do I advertise these engines, for the best result? One of these Forums, maybe......
