JD PB14
7 replies to this topic
#1 lrhredjb OFFLINE
lrhredjb
  • 871 Thanks
  • 650 posts
Posted June 01, 2015 - 08:40 AM
I bought this mower from a neighbor a few years ago and I find I don't use it much. It's built like a tank with a real heavy cast aluminum deck but it's missing the rear bag and there is no other way for the cut grass to get out. It runs well but when it idles the motor hunts up and down fast. Anyone have any experience with this model. I think it's a Kaw OHV engine.
  • Traill95 said thank you
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,368 Thanks
  • 10,138 posts
Posted June 01, 2015 - 10:29 AM
I see 4.5 hp, so it's a 1990-'92 model, the '93's got punched up to 5 hp.
The FC150v in there is a good motor, sounds like the carb needs a good cleaning.
http://www.ereplacem...0211_30498.html
#3 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted June 01, 2015 - 12:20 PM
I had one just like it and loved it. The blade brake setup is really neat.
Never a problem.
Good luck with fixing it, as said above it is probably a minor carb issue.
Cuck
#4 framesteer OFFLINE
framesteer
  • 436 Thanks
  • 208 posts
Posted June 01, 2015 - 10:09 PM
They made a plastic grass chute to direct the cut grass material to the left as you're pushing/walking behind the mower.  The chute mounts under the rear door,, in the same place as the grass bag.
  • Trav1s said thank you
#5 BowlBuilder OFFLINE
BowlBuilder
  • 485 Thanks
  • 465 posts
Posted May 15, 2016 - 06:10 AM
A67748CB-84B4-4266-83FF-5D45D0A0F6BB_zps
  • lrhredjb said thank you
#6 lrhredjb OFFLINE
lrhredjb
  • 871 Thanks
  • 650 posts
Posted May 27, 2016 - 10:54 AM
Thanks Bowl builder, Now where would I find one of those..........I'll have to start scouring the flea markets.
#7 BowlBuilder OFFLINE
BowlBuilder
  • 485 Thanks
  • 465 posts
Posted June 07, 2016 - 07:35 PM
A friend with some fabrication skills shouldn't have much trouble making one. Stainless would look nice.
#8 Rustysteele OFFLINE
Rustysteele
  • 300 Thanks
  • 92 posts
Posted June 18, 2016 - 07:43 PM
The engine hunting problem could be as simple as the carb vent being plugged up, the Kawasakis tend to do that if they really get dirty.
