Allis/ Simplicity stinger
b-10
16 replies to this topic
#1 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted May 31, 2015 - 07:00 AM
I am looking for pics of the stinger? that goes in the rear lift used to offset / counter balance the snowblower. in my B-10     pictures ,dimensions and the weight of it would be appreciated. Thanks Tom
  • Traill95 said thank you
#2 boyscout862 OFFLINE
  • 12,530 Thanks
  • 9,032 posts
Posted May 31, 2015 - 07:06 AM
For the snow blower you need the stinger and atleast one donut. They come up for sale every so often around here. Two years ago when I got mine, there were two different sets for sale on CL. I will take pics with a tape measure for you later today. I assume that you are going to build a set. The other way to do it is to make a bigger stinger out of a pipe and fill it with lead so that it weighs as much as the stinger and donuts. Good Luck, Rick
Did you see: http://newlondon.cra...5050716117.html    ?  He is about twice what he should be getting for it. Its missing the rear lift.
Edited by boyscout862, May 31, 2015 - 07:19 AM.
  • Traill95 and TomLGT195 have said thanks
#3 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted May 31, 2015 - 07:09 AM
Yes I am building one. My co- worker has some small old weights that I can have,  5# size
#4 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted May 31, 2015 - 07:13 AM
I lost my pictures and links but your in luck, there is a few forum members who have built their own and have links to other Simplicity Landlord tractor with custom attachments so wait a while for them to come by.
You would like my custom built mid-mount grader blade for the 1964 Sim.
Edited by trowel, May 31, 2015 - 07:15 AM.
#5 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted May 31, 2015 - 07:23 AM
Got pics?
#6 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted May 31, 2015 - 07:38 AM
Buried in this forum someweres I have some.
I think I have some on the other camera, while I have a few min I will look.
  • TomLGT195 said thank you
#7 boyscout862 OFFLINE
  • 12,530 Thanks
  • 9,032 posts
Posted May 31, 2015 - 08:54 AM
I took a walk :
SD530853.JPG SD530854.JPG SD530855.JPG SD530856.JPG SD530857.JPG SD530858.JPG SD530859.JPG SD530860.JPG
The first one shown is homemade, the second on shown is an original with the donut, the last is for the front with two donuts. I think the front one is for use with the tiller. I am looking forward to the time when 6 of my GTs are restored and setup the original way with correct weights. Good Luck, Rick
http://www.simpletra...nts/options.htm
It says the stinger weighs 25 pounds  http://www.simpletra...attachments.htm
Edited by boyscout862, May 31, 2015 - 09:17 AM.
  • drbish, TomLGT195 and classic have said thanks
#8 classic ONLINE
classic
  • 5,166 Thanks
  • 2,229 posts
Posted May 31, 2015 - 12:00 PM
The length of the 3" round rod is 10". The length of the 1" round rod is 8-3/8". The overall length of the weight with the 1" round rod welded to the 3" round rod is 15-5/8" long. The center of the 3/8" hole in the 1" round rod for the weight mounting pin, is 1/2" from the end of the round rod.
#9 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,300 posts
Posted May 31, 2015 - 04:25 PM
A stinger should not be tough to find, or expensive to buy. My last 6 or so went for a little over $1/lb.... $30/ea. They are extremely common and if you have a good way to source and cut 3" round stock, very east to make.
The picture above with 2 doughnuts is not a front weight....if it was, its hacked with no way to mount it. A front weight only holds one doughnut and it will rub the LH front tire when turning. By the book, front counterweights (45#+) were not shown using optional doughnuts (25-ish#).
A 36" blower or 46" dozer is about perfect with a stinger and doughnut. A 42" blower likes a stinger and 2 doughnuts.
Even with hydrolift I like to use rear counterweights. Eases the burden on the hydrolift and helps "float" attachments.
  • boyscout862, TomLGT195 and classic have said thanks
#10 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted May 31, 2015 - 06:03 PM
Kenny in another thread showed us how to find our pics we've posted.. open "my media" on the top of the screen when you reply to a post. He says every pic you post is there. I found mine under attachments when i opened it up. Try that. Tom
  • KennyP, trowel and boyscout862 have said thanks
#11 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted May 31, 2015 - 06:06 PM
Thanks guys. now that i have an idea of how much it weighs and what it looks like, I can build one. It won't be a replica , but it will work. I'll be using 5# weights on a shaft to be able to balance it exactly.  I'll post pics when i build it. Tom
  • trowel and boyscout862 have said thanks
#12 boyscout862 OFFLINE
  • 12,530 Thanks
  • 9,032 posts
Posted June 01, 2015 - 06:17 AM
I've been using a weight bar as stock for cutting into top links on my AC/Simp attachments like on the forks I showed a month or so ago.. Good Luck, Rick
#13 boyscout862 OFFLINE
  • 12,530 Thanks
  • 9,032 posts
Posted June 01, 2015 - 06:22 AM
It pins into the the front plow mounts under the front. It was one of the things I got in a package deal two years ago from a Simpletractors guy. Good Luck, Rick
#14 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,300 posts
Posted June 01, 2015 - 07:41 AM
Here are the two large frame tractor front counterweights.  Yellow one is for FDTs, Black one was offered for a short time, for 3300/3400 series tractors.  The lift arm for countering rear attachments via lift rod is the critical part, and gets in the way for a second doughnut.
  • boyscout862 and TomLGT195 have said thanks
#15 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted June 01, 2015 - 11:20 AM
Tom, don't put to much weight on the stinger. I made my own a few years back and did exactly that, it made the blower to lite and it would float over the snow. You want enough to make it easy to lift but still heavy enough to cut into the snow.
Sounds like you are having fun with that all is, did you get it running good?
Also tagged with one or more of these keywords: b-10
