25 thousanths off center
14 replies to this topic
#1 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted May 29, 2015 - 08:18 PM
Trying to make a stub shaft for my diesel conversion. It turns out I didnt indicate the hub as well as I thought I did and I am 25 thou off center in one direction. How bad is it going to be if I go ahead and make the stub shaft as is? HAve I screwed the pooch and need to start over?
#2 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted May 29, 2015 - 08:31 PM
Ya I would start over...
  • coldone said thank you
#3 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,227 Thanks
  • 1,083 posts
Posted May 29, 2015 - 09:09 PM
I think I'd start over as well,sounds like a good way of picking up a vibration.
#4 glgrumpy ONLINE
  • 8,618 Thanks
  • 7,926 posts
Posted May 29, 2015 - 10:13 PM
Don't fully understand, but don't Love Joy couplings kinda take alignment problems out of way?  A rubber flex connector taking up the diff?
#5 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted May 29, 2015 - 10:22 PM
What's the RPM of the stub shaft?
Mike
#6 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted May 29, 2015 - 10:47 PM
Holes are still centered and in line...
Mike
Don't mean anything when you off .025!
#7 karel ONLINE
karel
  • 2,089 Thanks
  • 1,390 posts
Posted May 30, 2015 - 04:32 AM
OWE! or Oops! take your pick! if you don't a haunting may happen latter in time!
Edited by karl, May 30, 2015 - 04:35 AM.
  • coldone and pigsitter have said thanks
#8 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted May 30, 2015 - 05:51 AM
Thanks folks. Thats what I figured but was hoping for a different answer. I think I will get a real machinist to do the next one.
#9 MH81 OFFLINE
Posted May 30, 2015 - 06:02 AM
The only way to use it is with a counter balance IMHO.
#10 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 30, 2015 - 06:35 AM
That's a big offset! You would get some serious vibration from that and the rest of the drivetrain will wear because of it. Better to start over. I'd try to figure out how it happened. Did something move on your lathe or your indicator?
#11 olcowhand ONLINE
  • 41,255 Thanks
  • 31,447 posts
Posted May 30, 2015 - 06:40 AM
Can you just turn it smaller then sleeve it, or possibly use a universal or coupling with smaller ID?
#12 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted May 30, 2015 - 06:45 AM
I'm a real machinist, lets see what you did first, then we might have a better idea as to what happened and how to fix it easily, or condem it to become something else down the road :thumbs:
  • coldone, Bruce Dorsi, KennyP and 2 others have said thanks
#13 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,481 Thanks
  • 5,773 posts
Posted May 30, 2015 - 08:01 AM
I hate when that happens..  It just might make a desk paperweight!!
Got one of these?
#14 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted May 30, 2015 - 08:15 AM
I think its an IOF problem. (Idiot Out Front) :D
Edited by coldone, May 30, 2015 - 08:15 AM.
#15 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted May 30, 2015 - 08:17 AM
Thanks, I will get pics this afternoon. Getting ready to head out the door for a Harbor Freight run. Need a new engine for the tiller.
  • olcowhand said thank you
