Late 60's Cub Cadet 105 hydro oil type
6 replies to this topic
#1 ss74nova OFFLINE
ss74nova
  • 6 Thanks
  • 12 posts
Posted May 29, 2015 - 06:58 AM
I'm planning a hydro oil & filter change. What oil should I run in the hydro ? I see Traveller's that is Hy-tran B-6 compatible at TSC for & 17.99 for 2 gallons. Would this be OK ? Thanks.
  • BNK said thank you
#2 BNK OFFLINE
BNK
  • 1,097 Thanks
  • 495 posts
Posted May 30, 2015 - 05:01 AM
Some would say "yes" but most say "no"...I'm one that says NO. I always use Case/IH Hytran and Cub Cadet filter. You will pay more but the peace of mind is priceless.
  • ss74nova said thank you
#3 KennyP ONLINE
  • 41,525 Thanks
  • 47,427 posts
Posted May 30, 2015 - 05:55 AM
The Hy-Tran has an additive to separate the water out that I doubt the Travellers has. I'd go Hy-Tran. A lot of Cubs are still going strong with the original oil still in there!
#4 IHCubGuy OFFLINE
IHCubGuy
  • 1,616 Thanks
  • 1,639 posts
Posted May 30, 2015 - 08:02 AM
Same as above, use the genuine Hy-tran.  Like Kenny said it is formulated to absorb the water and keep it from damaging the system.  The current CaseIH hy-tran is Ultraction.  It's not cheap though.  I bought a 5 gallon bucket 2 months ago and it was 80 bucks.
#5 ss74nova OFFLINE
ss74nova
  • 6 Thanks
  • 12 posts
Posted May 30, 2015 - 09:57 AM
My dealer wants $20.25 a gallon. I guess I would feel a lot better with the Hytran in there. I've been researching it & it seems to always come down to the water separation. It seems it can separate double the amount of some others. Do I need a gasket for the rear cover or can I just use a good RTV sealer ? Thanks.
#6 IHCubGuy OFFLINE
IHCubGuy
  • 1,616 Thanks
  • 1,639 posts
Posted May 30, 2015 - 11:43 AM
Get a new gasket for it and make sure that all of the old one is cleaned off good.  They aren't that spendy for a new one.
#7 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted May 31, 2015 - 11:16 PM
And I'll throw a yes in for the Hy- Tran.
And remember the filter is a hydraulic specific filter, not an ENGINE oil filter.
