Haban 415A
24 replies to this topic
#16 vtbolensfan OFFLINE
vtbolensfan
  • 69 Thanks
  • 77 posts
Posted June 04, 2015 - 07:49 AM
Thants great!! I also just bought one identical to this Haban. Worked ion it a littel bit last night. I dont think it is going to need anything to give it a try. I just greased it up and will mount it up soon
#17 vtbolensfan OFFLINE
vtbolensfan
  • 69 Thanks
  • 77 posts
Posted June 06, 2015 - 07:01 AM
I got mine on and working the other day. Seems to work pretty well. Mowed about 15 feet and the tractor stalled and woulnt start. I think there is water in the gas.
  • JohnWR said thank you
#18 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted June 06, 2015 - 09:05 PM
That's Great but i hope it's something simple to get the tractor going. You wouldn't mind getting me some pictures of the rod on the left hand side for the hydraulic lift and maybe a length would you?
#19 vtbolensfan OFFLINE
vtbolensfan
  • 69 Thanks
  • 77 posts
Posted June 07, 2015 - 06:21 AM
HI, sure no problem. I will get that info for you
#20 vtbolensfan OFFLINE
vtbolensfan
  • 69 Thanks
  • 77 posts
Posted June 07, 2015 - 06:41 AM
20150607_072810.jpeg 20150607_072747.jpeg 20150607_072732.jpeg 20150607_072718.jpeg 20150607_072657.jpeg 20150607_072630.jpeg
Here are a few picture for you. I had a hard time getting good pics of the whole thing due to the sun hitting on end of it and the other end being in the shadow.  Anyways, the rod is 18 1/4" long form the center of the front hole to the far end of the rod. The rear bracket on the rod is overall 4" tall. Hope this helps you out
#21 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted June 07, 2015 - 03:05 PM
Thank You that does the adapter i made broke so i am going to make a rod out of thick wall pipe and keep this one so if i can ever find the specs for the missing pieces i can get them made or make them.
#22 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted June 07, 2015 - 03:08 PM
I tinkered a little more today the set screws in the 4" pulled sucked and wouldn't bite into the rod so i went out and got some new ones. I also installed a new chain on it today as the onld one was pretty twisted and tried it out some.
  • LPBolens said thank you
#23 vtbolensfan OFFLINE
vtbolensfan
  • 69 Thanks
  • 77 posts
Posted June 08, 2015 - 07:57 AM
Wow nice. Yours looks like it sits much higher off the ground than mine does.
#24 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted June 08, 2015 - 07:19 PM
When the bar is up pull the lever down that's connected to the chain and pulley and that will raise the assembly for transport and storage and release when cutting it allows the bar to lay flat.
  • vtbolensfan said thank you
#25 JohnWR OFFLINE
JohnWR
  • 743 Thanks
  • 441 posts
Posted June 08, 2015 - 07:25 PM
Did some more work started replacing the hardware but tractor supply only have a few 7/16" carriage bolts on hand i also replaced 2 of the broken knife clips with generic ones.
Few questions for anyone that has one of these paging oldbuzzard i know you have 3
Is this rod supposed to be bent?
And last i think my sickle bar may have a slight bend in it due to to the gaps in the guards and the knives.
  • LPBolens and Rock farmer have said thanks
