Exhausting
21 replies to this topic
#16 toppop52 ONLINE
toppop52
  • 5,231 Thanks
  • 4,749 posts
Posted May 29, 2015 - 06:20 AM
I use heat around the area and tap lightly with a hammer around the perimeter, many ways to skin the cat.
#17 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,277 Thanks
  • 9,769 posts
Posted May 29, 2015 - 07:03 AM
I'm not familiar with the B&S. With a Kohler it's pretty easy to break out the block if you go banging around with a hammer and/or cold chisel.
Edited by LilysDad, May 29, 2015 - 07:04 AM.
  • toppop52 said thank you
#18 toppop52 ONLINE
toppop52
  • 5,231 Thanks
  • 4,749 posts
Posted May 29, 2015 - 09:30 PM
No offense, but if you hit hard enough to break it, you're doing it wrong. I barely tap around the heated area with a brass hammer or dead blow. Been doing it like this for 50 years, as well as other ways.
#19 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 29, 2015 - 10:13 PM
Agreed. Patience and being gentle is key. I have had things frozen that seemed like they would never break free. Keep penetrating oil and working it a little every day or two. For me, if I start get aggravated with it, it's time to go do something else before it's tempting to get ham handed. Then one day it moves a little. At that point, I spray it and tighten it up, then back out as far as it will go. And keep spraying. I tell my boys to treat stuck bolts and such like women--a gentle touch will go a long ways.
There is a lot of wisdom in this post. I've had to do it thousands of times in my life. Sometimes, just walking away for a little bit makes all the difference.
#20 Tankman OFFLINE
Tankman
  • 298 Thanks
  • 299 posts
Posted June 02, 2015 - 07:21 PM
Got the 1-1/4" street el out of the block. 16 hp Briggs, old block.   :worship:
1st, lots of PB Blaster and tap, tap, tap. A weeks worth.
Then a few days of acetone and automatic trans fluid, squirt, squirt, squirt (Thanks for the tip!).
Then, frustrated, cut the lock nut off. Cut the street el off 'bout 1/4" away from the block.
Carefully, sitting relaxed, drilled 1/8" dia holes 'bout eight of them in the fitting close to center to
avoid touching the block at all.
1/8" drift pin, tap, tap, tap, a piece broke out of the fitting. Slowly the fitting folded in, then I easily threaded the block out. Cleaned the block threads, using Never-Seez installed a long nipple and muffler.
I'm going to change the exhaust piping but, workin' great. Got to finish the hood and some other stuff.
The street el was a pain in the you-know-what!
Tried the mid-mount grader blade for a bit. Very nice!   :peace:
Edited by Tankman, June 02, 2015 - 07:27 PM.
  • KennyP, Sawdust, classic and 1 other said thanks
#21 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted June 03, 2015 - 12:46 AM
the grader is my favorite !! congrats  :thumbs:
#22 alleyyooper OFFLINE
alleyyooper
  • 939 Thanks
  • 419 posts
Posted June 03, 2015 - 08:15 AM
I totally agree heat and melt wax is a great method and I turn to it before I would even think of a petrenting lube.
:D   Al
