Elec-trak solar charging?
5 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted May 28, 2015 - 09:29 AM
I've seen this done. I've seen multiple photos on the topic, but with little written.
http://neeaa.org/robieet.htm
http://www.builditso...ecTrak/Main.htm
I just bought a new house, and will be looking towards battery backup down the road. I'm not looking for anything high-tech yet, just something simple like a panel and plug it in. Or does that not exist?
What do you all use? Any photos? Thanks everyone
  • KennyP, Coventry Plumber and debbieox4 have said thanks
#2 boyscout862 ONLINE
  • 12,863 Thanks
  • 9,175 posts
Posted May 28, 2015 - 10:19 AM
The solar electric idea is very interesting. HF has a 45w set up with controller on sale for $140. That is not alot of charging but it is great for just topping off. In your case I do not know how you would go to 36v. I would try charging a large battery(or several in parallel) and use it to power an inverter that could power your 36v charger. You would probably want a set up of 200w of panels of output to start but have the ability to add more if 200w is not enough.
I've been watching the development of solar electric panels for many years. Ten years ago there was a great breakthrough anounced that was going to drop the cost of panels to 1/10 of what they were in 2006. Still haven't seen that cost savings passed through to the consumer. The solar panel setups that the telemarketeers are pushing is not a good deal in my area. You rent them your roof and allow intrussions into your house to save 2 cents per kilo watt hour. I'm sure that the installers are completely trustworthy.
It looks like consumer photovoltaic is on a back burner for now. The panels only last on average about 10 years so used ones are a risk. Good Luck, Rick
  • CRFarnsworth said thank you
#3 WisJim OFFLINE
WisJim
  • 3 Thanks
  • 1 posts
Posted August 29, 2016 - 08:49 PM
Just looking through older posts and read this one about solar electricity.  Lots of misunderstanding of solar expressed--our first solar electric panels (photovoltaics or PVs) were about $8 a watt, or more, in 1981.  Our latest ones were under a dollar a watt, in 2012.  $8 in 1981 is about  $20 in 2012 when adjusted for inflation, so prices have dropped tremendously.  My panels that were new in 1981 are still working like they did 35 years ago--and they had a 5 year warranty.  Most new panels have a 20 or 25 year warranty and are expected to function at least twice that long.  If you are interested in solar at your home or shop, check with a local NABCEP certified installer/dealer for an honest appraisal and estimate. Our solar electric system provides our home and shop power, charges our Nissan Leaf electric car (and a number of electric conversion cars in the past), and my GE Elec-trak tractors.  This includes the power needed to run the heat pumps that provide all of our air conditioning and much of our heat in our home.
  • daytime dave, Alc and boyscout862 have said thanks
#4 jimmy G OFFLINE
jimmy G
  • 1,197 Thanks
  • 779 posts
Posted August 30, 2016 - 12:14 AM
Wisjim is telling you man to man not like the bogie man in media, just bought two 100w panels for $230 shipped, and every thing I paid over $10 a watt for is still working, storage will be the biggest expense (battery's). their are many ways to go about this and it's all on line
#5 jimmy G OFFLINE
jimmy G
  • 1,197 Thanks
  • 779 posts
Posted August 30, 2016 - 12:40 AM
solar panels work just like battery's, two 12v battery's in parallel make's a bigger 12v battery, two 12v battery's in series makes a 24v battery,3 =36v,the higher the the system voltage the more efficient, charging DC with DC only requires a regulator and enough output. this stuff is out their and the price IS going down
#6 boyscout862 ONLINE
  • 12,863 Thanks
  • 9,175 posts
Posted August 30, 2016 - 08:36 AM
Welcome to GTT. Thanks for the info. One thing to remember is that the panels that you bought 35 years ago were probably made in the USA, Most everything now is made in China. The quality now is at best questionable.
I built my house passive solar and super insulated 20 years ago(still not finished) so, I have an 1800 square foot section of 7/12 roof facing true south. I would love to have good solar panels rigged up with a fuel cell storage system. Around here, the components and the contractors don't have good enough reputations. Three friends have put them up and are generally content with them but all had problems.
I've talked to many of the companies and one of the engineers admitted to me that their panels degrade as much as 50% in 10 years. I'm waiting to learn more before I spend the money. Good Luck, Rick
Edited by boyscout862, August 30, 2016 - 08:37 AM.
