Guilty of D.W.S.M.B.O. FEL Thread
roper 18t front end loader
128 replies to this topic
#91 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted June 25, 2015 - 05:45 PM
What's wrong with being proud of how tall my load can be lifted?
That sounds wrong... Oh, you know what I mean.
I know the slogan... Low and slow. But that don't make for good pics :D
But high and wide does!
#92 olcowhand ONLINE
  • 41,081 Thanks
  • 31,393 posts
Posted June 25, 2015 - 06:14 PM
Finally, some pics where you don't have a load six feet in the air.
Maybe put some duals on that bad boy? With about 30" spacers?
Maybe we need to build Alan outriggers to keep him from tipping!  :rolling:
  • MH81, KennyP and Cat385B have said thanks
#93 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted June 25, 2015 - 06:22 PM
I have a piece of large tube here that would make a set of spacers for duals. At least it fit inside a 12" wheel just right. About 14" long. Been hanging on to it 'just in case'!
#94 TomLGT195 OFFLINE
TomLGT195
  • 3,826 Thanks
  • 2,812 posts
Posted June 25, 2015 - 06:41 PM
I don't think my loader on the 195 goes that high.
#95 Cvans ONLINE
  • 6,640 Thanks
  • 6,126 posts
Posted June 25, 2015 - 09:00 PM
Would you look at how long those lift cylinders are. You could put hay in the loft with that loader.  :smilewink:
#96 MH81 OFFLINE
Posted June 25, 2015 - 11:24 PM
After that sentence, I was expecting that pic of me asleep in the lawnchair...
  • olcowhand, Alc and KennyP have said thanks
#97 TAHOE ONLINE
TAHOE
  • 7,970 Thanks
  • 5,673 posts
Posted June 26, 2015 - 08:17 AM
Oh, I really need a loader now myself, those bales get heavy after a while throwing up inthe loft.
#98 MH81 OFFLINE
Posted June 27, 2015 - 08:31 AM
Well, as I mentioned earlier, there was a minor breakdown. The main drive belt suddenly developed two ends.
Got a new belt and installed it night before last. (Not a project to do in front of your mother or pastor). It's a moving on its own again. But...
I just had one thing that bothered me.
This tractor had no brakes. I mean, the only break pads was for the parking brake, with no connection to the "Clutch Brake" pedal.
I did some research, it never did.
They were banking on the dynamic braking of the hydro. Which was fine until I was working on a hill and the tractor ran out of gas...
Fun ride, don't suggest it. If I hadn't had the FEL on there, she would've busted up the grill bad on impact with the MF165 tire.
So, here is my solution.
First, I designed a couple of pieces that would allow for clutching and use of the emergency brake AND activate the brake lever.
Then I ran a rod back to an existing hole in the brake activation lever. (I think I'm going to add one more hole further out, now that I've proven the concept)
Only downfall with this system is it only really applies to the left tire. It stops the tractor and even keeps it from moving if the tranny is activated/belt isn't loose enough (simulating a worst case scenario so I knew how it would respond)
If I ever find a junk one of these, I am going to try to get the brakes on both wheels, but for now I have a little tweaking and it's a winner.
Now to get the FEL Back on it.
PS, the HF lift we got last year worked great for this.
I thought it was kind of a neat look, so we grabbed a pic.
  • olcowhand, KennyP and TomLGT195 have said thanks
#99 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted June 27, 2015 - 08:37 AM
What rear end does it have? That brake looks similar to the Dana setup.
#100 MH81 OFFLINE
Posted June 27, 2015 - 08:38 AM
No idea, might be a Dana... Didnt see a tag anywhere tho.
#101 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted June 27, 2015 - 09:02 AM
That's the 18T isn't it?
#102 MH81 OFFLINE
Yep.
#103 MH81 OFFLINE
Posted August 07, 2015 - 05:28 PM
Man Down, Man Down...
Was using the loader to do some work, all of the sudden, the belt went floppity-floppity and the pulley scampered across the yard.
Huh, what's going on? OMG... WTF????
Not a easy fix, not a cheap part to replace. Can't make one local for inexpensive, don't have one hiding in the garage...
This one is 40+ yrs old and no side load bearing.
eBay has the bearing version for 25% of a new one. It's NOS with a little higher GPM
Sent an offer, accepted, paid shipping.
Got this for $40 plus FedEx charge of $16
Only thing I need to watch is the max rpm...at WOT, I could exceed that. I shouldn't need to do that with the higher GPM and less leak by of a new pump.
  • olcowhand, DH1, wvbuzzmaster and 2 others have said thanks
#104 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted August 07, 2015 - 05:45 PM
Sorry to here of your troubles but we all know stuff happens, anyway sounds like you got a plan to fix it quick. :thumbs:
#105 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted August 07, 2015 - 05:46 PM
 Ouch! That hurt! Got any #'s for that new pump?
Also tagged with one or more of these keywords: roper 18t, front end, loader
