Guilty of D.W.S.M.B.O. FEL Thread
roper 18t front end loader
128 replies to this topic
#46 olcowhand ONLINE
  • 43,182 Thanks
  • 32,014 posts
Posted May 31, 2015 - 02:46 PM
Before putting too much stuff on there, it'd be a great to get power steering fabbed up!
#47 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 31, 2015 - 04:48 PM
Did you get the wheels with the axle? What ply tires did you put on the front, and please don't say 2 ply....
#48 MH81 OFFLINE
  • 29,979 Thanks
Posted May 31, 2015 - 09:22 PM
:D
Thank you KK & Ryan.
  • Alc, wvbuzzmaster, KennyP and 2 others have said thanks
#49 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 31, 2015 - 09:34 PM
Excellent Alan. Glad you are having fun. By the way, looks great on the Roper.
  • MH81 and holdenboy1960 have said thanks
#50 MH81 OFFLINE
  • 29,979 Thanks
Posted May 31, 2015 - 09:38 PM
Had some minor mods to make it fit.
The valves interfered with the hydro handle, nothin for it but to move the valves over 1" on the bracket.
The clutch pedal was binding between the loader arm and the tinwork for the hydro cooler, so the pedal rubber had to come off. Now it's all good.
Need to find a seal for the loader pump, but we will see it the seals are just dry or if they're bad first.
  • wvbuzzmaster, KennyP, TomLGT195 and 1 other said thanks
#51 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 31, 2015 - 09:41 PM
How many plys are the front tires you put on there??
#52 MH81 OFFLINE
  • 29,979 Thanks
Posted May 31, 2015 - 09:43 PM
They were the ones on the tractor. We moved them over.
I will try to look and let you know.
Edit,
They are 2 ply... And I guess will have to be on the list for changing at some point.
  • wvbuzzmaster said thank you
#53 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 31, 2015 - 09:46 PM
Probably 2 ply so I bet you will blow em out in a few days of heavy use. I have one minimal use orphan Carlisle turf (looks like yours) that is 4 ply I can set aside for you. :D
Note: it's about $40 new (each)
Edited by wvbuzzmaster, May 31, 2015 - 09:47 PM.
#54 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 31, 2015 - 10:20 PM
I think you did a-ok, Alan!
Ben W.
#55 KennyP OFFLINE
  • 41,529 Thanks
  • 47,427 posts
Posted June 01, 2015 - 01:24 AM
Attaboy, Alan! That is looking mighty fine!
#56 TAHOE OFFLINE
TAHOE
  • 8,339 Thanks
  • 5,820 posts
Posted June 01, 2015 - 06:56 AM
What did the new  front axle come from?
#57 MH81 OFFLINE
  • 29,979 Thanks
Posted June 01, 2015 - 07:46 AM
Guy said 200 something JD
  • KennyP and TAHOE have said thanks
#58 TAHOE OFFLINE
TAHOE
  • 8,339 Thanks
  • 5,820 posts
Posted June 01, 2015 - 11:25 AM
That pedal mod probably would not work for me, too uncomfortable for my short legs :D  it would have to be back farther.
Edited by TAHOE, June 01, 2015 - 11:25 AM.
#59 olcowhand ONLINE
  • 43,182 Thanks
  • 32,014 posts
Posted June 01, 2015 - 11:28 AM
For a loader, there's nothing better than pedal hydro, but for plowing very long, hand control is king.  The feet get very tired from holding the pedal in place unless you have a cruise control lock.
  • Alc, KennyP, TomLGT195 and 1 other said thanks
#60 MH81 OFFLINE
  • 29,979 Thanks
Posted June 01, 2015 - 11:30 AM
You could put it anywhere, I used 1/4" bolts thru existing footrest holes.
Also tagged with one or more of these keywords: roper 18t, front end, loader
