Sears ss16 Onan engine is hunting at half and full throttle
#1
OFFLINE
Posted May 27, 2015 - 07:58 AM
#2
ONLINE
Posted May 27, 2015 - 08:13 AM
Download the manual from our Manuals Section(3 for free per day). Check for a vacuum leak. Tighten carb and manifold bolts. Check govenor springs and linkage for wear. If it is real loose it will not hold steady. Clean plugs. Check ignition wires. Adjust carb mixtures. If it still does it: pull each needle valve(idle and highspeed) and shoot some carb cleaner into their holes. Replace needle valves and try adjusting again. If the problem persits it may be a blocked passage in the carb and the carb will need to be rebuilt. Good Luck, Rick
Edited by boyscout862, May 27, 2015 - 08:14 AM.
- ratnestss16 said thank you
#3
ONLINE
Posted May 27, 2015 - 08:42 AM
I chased a hunting issue down on a Kohler once. it was due to a worn throttle shaft bushing allowing air passage when the shaft was turned to 1/2 or full throttle. Idle was fine.
- ratnestss16 and boyscout862 have said thanks
#4
OFFLINE
Posted May 27, 2015 - 09:22 AM
- MH81 and boyscout862 have said thanks
#5
ONLINE
Posted May 27, 2015 - 10:43 AM
Look up "helicoil" this should fix your manifold bolts, and if they won't tightned, most likely causing the hunting issue.
#6
OFFLINE
Posted May 27, 2015 - 11:01 AM
#7
OFFLINE
Posted May 27, 2015 - 11:23 AM
your tractor would be a 73 at the earliest, Sears didin't make a SS16 in 72.
If the manifold bolts don't fix your issue, those are also bad for the 2 piece intake manifold to separate and suck air. Many guys drill out the rivet area, separate intake, seal with RTV, then use samll bolts/nuts to put it back together.
- MH81 and ratnestss16 have said thanks
#8
OFFLINE
Posted May 27, 2015 - 12:50 PM
- TAHOE said thank you
#9
OFFLINE
Posted May 27, 2015 - 12:52 PM
