leaky plastic gas tank
16 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 26, 2015 - 11:49 AM
what does a guy do about the leaking plastic tank on the rbt simplicity ? I have three that leak . one someone ( not me ) put some :bs:   glue on it ... that worked for a day or two and then I came out to gas all over the driveway .  not really lookin to have a hazmat team at my house ... any suggestions ?
  • laurarg3 and RonelioKi have said thanks
#2 UncleWillie OFFLINE
  • 15,676 Thanks
  • 8,763 posts
Posted May 26, 2015 - 12:07 PM
Plastic welding. I have yet to find a plastic tank sealer that stands up long.
  • Alc and alec have said thanks
#3 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted May 26, 2015 - 12:24 PM
Can't say I have ever seen an RBT tank leak.  is the leak at the hose/grommet?  I had one of those break off once, and made one from somethin else I found in the barn.  Doesn't leak to this day.
  • alec said thank you
#4 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted May 26, 2015 - 01:23 PM
Don't know what rbt means here, but most tanks are some weird plastic that can only be molded once and then not worked with again. Fiberglass, epoxy, glues, none of those work. Might just have to look for another one on epay or maybe fellas selling parts here on forums, look at top list.  IF you had just that grommet with the valve poking into it like newer ones, you can get both gromm and valves lots of places. Older units with the little tube sticking out to slip the hose on tend to be broken more. Have to be real careful pushing and pulling off/on with hoses on those kind.
#5 Freddie1911 OFFLINE
Freddie1911
  • 149 Thanks
  • 98 posts
Posted May 26, 2015 - 04:49 PM
 The tank on the Massey We just reclaimed was leaking at the exit fitting. I built a bulkhead fitting that I could gasket each side of. The only way I knew to save it. If its split a hot air welder and an old tank to use pieces for filler may do it. Just keep in mind theres been gasoline in that tank an a hot element in that gun.   Just my thoughts    Freddie
#6 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted May 26, 2015 - 06:29 PM
There is to many good ones out there.Most leek at the replaceable grommet on bottom
#7 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted May 26, 2015 - 06:51 PM
Take a look at this.
http://diy3dprinting...astic-with.html
#8 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 26, 2015 - 06:58 PM
I geuss I should have said it was the grommet on the bottom . I like the bulkhead fitting idea where did you get your pieces ?
nice dremmel trick nxt2doc !
where might I find the grommets ?
#9 KennyP ONLINE
  • 38,474 Thanks
  • 45,969 posts
Posted May 26, 2015 - 07:10 PM
What's an RBT?
#10 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted May 26, 2015 - 07:13 PM
#11 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted May 26, 2015 - 07:14 PM
Running board tractor
#12 Tankman OFFLINE
Tankman
  • 298 Thanks
  • 299 posts
Posted May 27, 2015 - 05:02 AM
If the tank had a crack, a soldering gun will melt the plastic. Will seam the polyethylene very nicely.
Strips of plastic filler can be made from a soda bottle.   :thumbs:
#13 Freddie1911 OFFLINE
Freddie1911
  • 149 Thanks
  • 98 posts
Posted May 27, 2015 - 06:41 PM
 I built it . Fine thread bolt drilled through and taped 1/16 pipe thread  on the bolts threaded end flats and O rings. It worked. I don't know whether a 1/4 inch  fitting is made or not.     Freddie
#14 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 27, 2015 - 06:48 PM
sweeeet !  I like it
  • Freddie1911 said thank you
#15 Freddie1911 OFFLINE
Freddie1911
  • 149 Thanks
  • 98 posts
Posted May 28, 2015 - 05:04 AM
What's an RBT?
  Some things WE really need to know. What is RBT?
