head removal
13 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 25, 2015 - 02:55 PM
I am going to take my head off my 12 hp 300421 briggs
I am told that if I am careful I can reuse my gasket
what is the best way to take it off ? any tips or tricks ? thanks guys :beerchug:
  • classic and Antoniofuse have said thanks
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 11,816 Thanks
  • 8,932 posts
Posted May 25, 2015 - 03:07 PM
Just be sure to use a torque wrench to remove the bolts. :thumbs:  :smilewink:
  • alec said thank you
#3 classic ONLINE
classic
  • 4,677 Thanks
  • 2,061 posts
Posted May 25, 2015 - 03:21 PM
Loosen the bolts a little at a time each until tension is off of them. Retorque in the same manner in the pattern Briggs specifies. After running the engine, retorque the head after the engine cools. It may take up to three heat up, cool down, retorque sequences. I've seen plenty of warped aluminum heads on these Briggs engines.
The other option is to just unbolt the head, do what you have to do, and just bolt it back on to "that should do it" specs... I don't recommend it.
  • propane1 and alec have said thanks
#4 classic ONLINE
classic
  • 4,677 Thanks
  • 2,061 posts
Posted May 25, 2015 - 03:35 PM
Here's a Briggs model 23R6D head that's been taken off and put back on multiple times since 1956 and is badly warped. Even some of the head bolt bosses are dished because washers were missing from the head bolts. I'm in the process of rebuilding the engine completely and the block, gear reduction assembly, governor linkage, and intake manifold are the only parts that can be reused.
#5 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 25, 2015 - 04:37 PM
will the head just lift off at that point ? will there be any tapping with a hammer or prying involved ? first time with a small engine .
#6 Bolens 1000 ONLINE
  • 14,219 Thanks
  • 17,846 posts
Posted May 25, 2015 - 04:48 PM
For what they are brand new you may just be better buying a brand new gasket, they are $ 7.98
Head gaskets were never recommended to be reused by any engine manufacture ............
  • WHdbJD, boyscout862, KC9KAS and 1 other said thanks
#7 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 11,816 Thanks
  • 8,932 posts
Posted May 25, 2015 - 04:50 PM
When you reuse the gasket, coat it with aluminum paint.
Edit;  Er, yeah! What he said!
Edited by LilysDad, May 25, 2015 - 04:51 PM.
#8 propane1 ONLINE
propane1
  • 7,753 Thanks
  • 3,792 posts
Posted May 25, 2015 - 04:51 PM
Unbolt in the same sequence as you would when you put them back in and torque them down. Find the sequence in a manual for that engine. Should always put a new gasket on, but we do what we have to do at times to make something run. I have reused gaskets before. Yes, you may have to tap or pry. Use some thing other than a steel hammer to tap. Plastic, wood, rubber hammer. Noel.
#9 KC9KAS OFFLINE
KC9KAS
  • 5,161 Thanks
  • 4,545 posts
Posted May 25, 2015 - 04:55 PM
I agree 100%!
  • boyscout862 and alec have said thanks
#10 JDBrian OFFLINE
  • 9,596 Thanks
Posted May 25, 2015 - 05:15 PM
I'm a big believer in careful prep of the head and the block surfaces to make sure they are as clean and flat as possible. Sometimes hard carbon can get deposited on the block from a leak that has been happening for a while. That needs to be totally removed to make sure you get a good seal. Definitely use a new gasket.  If both surfaces are flat and in good condition you shouldn't need any pastes to fill in the gaps.
#11 boyscout862 ONLINE
  • 11,436 Thanks
  • 8,467 posts
Posted May 25, 2015 - 05:29 PM
You can download the manual for free. Use a new gasket and follow the torque sequence in the manual. Reusing a head gasket is something to attempt only in emergencies when a new one is not available. Good Luck, Rick
Try this manual:  http://gardentractor...ines-1919-1981/
Edited by boyscout862, May 25, 2015 - 05:33 PM.
#12 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 25, 2015 - 08:18 PM
does that include shipping mr bolens ?
#13 Bolens 1000 ONLINE
  • 14,219 Thanks
  • 17,846 posts
Posted May 26, 2015 - 06:16 AM
Shipping will be $3.00
If your interested send me a PM
#14 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 28, 2015 - 09:39 AM
got it off and back on ( froze exhaust valve ) has compession and runs . ( not bad for a junk engine that I got with a pile of tractor )
  • Bolens 1000 said thank you
