U-joint replacement tiller drive shaft Ford/Jacobsen 09JC-9734
10 replies to this topic
#1 lloydbiker OFFLINE
lloydbiker
  • 11 Thanks
  • 4 posts
Posted May 25, 2015 - 01:05 PM
Someone was looking for a replacement for a JAC-142054 Sleeve Assy.-Drive
I'm waiting for the parts to come in to complete the job to replace the original Non-greaseable light duty assembly with a heavier duty greaseable assembly
Here's what I intend to use (Buyers Part Numbers)
           Input Yoke  A7413  (3/4" round bore 3/16 Keyway)
           Slip Yoke    A7312   (3/4" Square Bore)
           Cross (Journal)  NB7A
I know for sure I will have to drill the input yoke for the 1/4" shear bolt, and I may have to shorten the square shaft slightly, but the result should be a part that will last forever, at less than 1/2 the price.
  • Alc, KennyP, boyscout862 and 3 others have said thanks
#2 boyscout862 ONLINE
  • 13,692 Thanks
  • 9,475 posts
Posted May 25, 2015 - 01:14 PM
Welcome to GTT. Sounds like you are good at improvising. Checkout our Manuals Section for three free downloads per day. Please post pics of the new joints and how you modify them. Good Luck, Rick
  • Chopperhed and propane1 have said thanks
#3 TomLGT195 OFFLINE
TomLGT195
  • 4,098 Thanks
  • 2,927 posts
Posted May 25, 2015 - 01:43 PM
:welcometogttalk:    &    :wewantpics:  :smilewink:  :smilewink:
  • Chopperhed said thank you
#4 Rock farmer ONLINE
Rock farmer
  • 1,316 Thanks
  • 1,282 posts
Posted May 25, 2015 - 03:11 PM
Welcome to GTTalk!
Just for the record those shafts are not square.
They're 3/4" x 7/8"
Joe
#5 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 26, 2015 - 04:32 AM
I have found parts to replace the original with heavier duty components but it is $$$ about $150 total for the entire assembly, and you still need to cut it to length. But it will last as it is all Weasler 6N parts.
#6 lloydbiker OFFLINE
lloydbiker
  • 11 Thanks
  • 4 posts
Posted May 26, 2015 - 07:51 PM
Damn! You are right, 3/4 x 7/8". A quick re-plan: Order  an A7412 end yoke (7/8" sq bore) in place of A7312 slip yoke. Cut original slip sleeve off at factory weld, weld to A7412 yoke, and assemble. I had originally thought of going this route with a Buyers 3/4"Rd x 3/4" Rd, light-duty, pin and bushing u-joint (identical to original Weasler). But I scrapped the idea, for fear of overheating the cross assembly while welding.
Edited by lloydbiker, May 26, 2015 - 08:06 PM.
  • Rock farmer and Chopperhed have said thanks
#7 lloydbiker OFFLINE
lloydbiker
  • 11 Thanks
  • 4 posts
Posted May 27, 2015 - 06:18 PM
Well, now that I look at it again, I should have ordered a Buyers A7424 End Yoke, which is the perfect fit, and welded the factory slip sleeve to it. Wouldn't ya know, I didn't notice the rectangular bores until later.
  • KennyP and Chopperhed have said thanks
#8 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted May 27, 2015 - 07:30 PM
Skyrydr2, interested in part numbers for all that. Thanks
#9 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 28, 2015 - 04:44 AM
Ok, cross 2000600-$13.18 yoke and shaft (3/4x7/8) 10000648-$45.71 ,pto slip sleeve-5100600-$34.39 weld yoke-3000600-$16.05 and lastly the 3\4"keyed yoke-8000612-$14.77
So all totaled $152.05 for a pto shaft or even a hydro drive shaft if need be.
Web sight www.paulbparts .com
  • KennyP and TomLGT195 have said thanks
#10 lloydbiker OFFLINE
lloydbiker
  • 11 Thanks
  • 4 posts
Posted May 28, 2015 - 01:10 PM
I tried to change my order to a Buyers A7424 3/4" x 7/8". weld yoke this morning, only to find out it's discontinued. So, I'll carry on with the A7412 yoke (shimming for alignment on shaft), welding it to the salvaged slip sleeve.
I cross-checked all Skyrydr2's part numbers against paulb's on-line Weasler catalog, and agree with all items  Except the Shaft and Yoke. I cannot find a part # 10000648. I found a # 11000648 assy. but it didn't show shaft size, so I can't verify.
If I were to go that route, and had a Weasler supplier nearby, I would call for verification. Barring that, I would get out the angle grinder, salvage the old shaft, and weld it into an additional # 3000600 Yoke .
#11 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 29, 2015 - 11:43 AM
Here is the link to the yoke and shaft
http://www.paulbpart...es-pto-yoke-s-0
