Wanted
Delco Remy Starter Generator 1101939
9 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 24, 2015 - 09:25 PM
Looking for Delco Remy 1101939 starter generators or equivalent number. These units are used on vertical shaft Briggs, and Kohler KV161, engines found on my Springfields. Ended up using one similar on one already, and need to replace it since not sure if it is suited for vertical usage, and I was intending to use it on a Briggs horizontal shaft. I don't care if it generates (nice bonus), just as long as it spins to start engines. I can switch starter generators around some as I plan to run total loss electrical systems on a few tractors (magneto) to avoid buying lots of batteries and regulators.
  • StevenPa, Antoniofuse and RonelioKi have said thanks
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted May 24, 2015 - 10:05 PM
Go looking for some junk Simplicity Broadmoors, Casey.  You see those old style generators by the dozen on them.
Ben W.
  • Alc, wvbuzzmaster and boyscout862 have said thanks
#3 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted May 24, 2015 - 10:17 PM
I was just thinking the same as Ben, I have the generator off of an old Simplicity 707. And I have no use for the generator. I will find it tomorrow and check the numbers.
  • wvbuzzmaster, boyscout862 and superaben have said thanks
#4 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted May 25, 2015 - 07:48 PM
I got a nice one from a Allis B 10 if that would help...
  • wvbuzzmaster said thank you
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 25, 2015 - 08:21 PM
What are you asking?
#6 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Chris, did you find te starter generator?
#7 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted May 25, 2015 - 08:36 PM
50.00
#8 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 25, 2015 - 08:43 PM
Does
50.00
Shipping included in that price?
Also, does both starting and charging work?
#9 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted May 25, 2015 - 08:53 PM
It came from a running tractor.I can ship for 15.00
#10 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted May 25, 2015 - 09:07 PM
Sorry Casey! I have looked every where today and can't find it.
