For Sale
55 Wheel Horse RJ35
1 reply to this topic
#1 JakeKuhn ONLINE
JakeKuhn
    Wheel Horse Addict
  • 183 Thanks
  • 268 posts
Posted May 24, 2015 - 06:41 PM
For Sale: later 55 Wheel Horse RJ35 with the Stamped steel frame. This tractor is a very good start to a restoration, there is not much if any rust pitting on it, the hood is also relatively straight but does have a couple small dents on the front that could easily come out if the tank was removed and some cracks and a repair around the gas cap hole to hold the 2 halves together. All 4 rims look to be in great shape which is hard to find, but the tires have seen better days, although they do hold air fine. The veri drive does not have much slop in it, and I went through the rear end and put new axle bushings, jackshaft bearings and the case seal. The hubs were in good shape when I had them off last winter, the only downfall is they have a hole drilled through them, but that does not affect the use of them and they may be able to be filled. The original gas tank is also in good shape. This has a newer k91 installed that runs ok but does not have a hole lot of compression and sometimes smokes a little bit, but is good enough to power this for just riding around. Sadly this tractor is missing the original steering wheel, belt guard and engine pulley, but all of those parts are now available reproduction. These tractors are getting very tough to find, and if you wanted to restore one I would consider this a very easy project. I'm only selling because I have 2 of the exact same tractor. Located in South Haven Mi And starting off at $1200. I think I can get this to the PA Wheel Horse show, but can't 100% guarantee that yet. Thanks, Jake
  • Traill95, holdenboy1960, StevenPa and 2 others have said thanks
#2 JakeKuhn ONLINE
JakeKuhn
    Wheel Horse Addict
  • 183 Thanks
  • 268 posts
Posted June 16, 2015 - 08:43 AM
price now $1000 firm
