Manual for KV161 or other help
15 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 23, 2015 - 09:15 PM
I'm in need of a manual, operators preferred, but either will help, for Kohler KV161 engine of 1960s vintage. My engine is a 1962, but anything will help. I'm trying to learn oil fill level (plug seems to be very low on the engine to me), as well as info about air cleaner and muffer. Muffler on mine is wrong so planning gravely style koher muffer. Air cleaner looks too small to me on mine as well. Pics can follow tomorrow, I'm tired. Any help appreciated. Thanks.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted May 23, 2015 - 09:35 PM
Now that is a rare engine.
You do want to make sure you have the oil level right.  If the 161 is any cousin of the later KV181, lubrication is the weak point.
I don't have any information on the KV161 in the computer here, but I will check my hardcopy manuals and see.
What is this engine on?  Being as rare as it is, the best bet may be to find the info in a tractor operator's manual.
Ben W.
  • Bolens 1000 and wvbuzzmaster have said thanks
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 23, 2015 - 10:36 PM
It is on a Springfield. I have most the manuals, not much engine info in them. Some idiot painted part of the tag, so can't read 161, but all other info is intact, and I'm certain it is 161. I need an air cleaner setup, as the one on it is off of a Clinton lol. So lubrication is weak point? I know it hasn't run is probably 10 years, last guy to work on it was struggling with spark, but this guy was no mechanic, and screws up all he touches, so glad he had no spark lol.
Edited by wvbuzzmaster, May 23, 2015 - 10:36 PM.
#4 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,357 posts
Posted May 24, 2015 - 07:58 AM
found this on uk ebay
http://www.ebay.co.u...0731&rmvSB=true
the item is located in roanoke
Edited by drbish, May 24, 2015 - 07:59 AM.
#5 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted May 24, 2015 - 08:06 AM
If the air cleaner is what Don shows in the eBay listing, the updraft oil bath, I have one of those.  I do trade ins on Clinton air cleaners any day.  :smilewink:
What carburetor is that?  Walbro LMV?
Lubrication was a weak point on KV181's, so I am only assuming that would be the same on a KV161.
Ben W.
#6 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 24, 2015 - 11:21 AM
I will post pics in an hour. I have never seen this angled out carb before in my life, and the Springfield pics I have seen of this engine use an air filter like on the horizontal version of K161.
What do I need to do to make sure lubrication system in this engine is good? (does this have an oil pump or a splasher?)
#7 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 24, 2015 - 11:55 AM
Carb looks to be stamped "LMV" "1"
Exhaust will be removed before starting this thing.
Also these plugs, is that all the higher the oil is?
#8 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,357 posts
Posted May 24, 2015 - 01:24 PM
here is the kv 181,my service and operators manual for it states 1 quart of oil.also a service bulletin for the kv181 pertaining to the oil problem on it
  • wvbuzzmaster said thank you
#9 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 24, 2015 - 02:27 PM
Ok, so the 181 looks totally different than the 161 oil fill. Anyone care to elaborate?
#10 Bolens 1000 ONLINE
  • 14,890 Thanks
  • 18,097 posts
Posted May 24, 2015 - 03:21 PM
The Carb and air cleaner are Clinton
Those carbs were quite popular on the VS series, Have the stock carb and air filter just like this on my little Bolens rider.
Ben probably knows all models that used this carb and filter :D :poke:
#11 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 24, 2015 - 03:59 PM
So what do I do? Is this the right carb Or do I need to be getting the right kohler carb?
Edited by wvbuzzmaster, May 24, 2015 - 03:59 PM.
#12 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,357 posts
Posted May 24, 2015 - 04:03 PM
It looks like the same carb on the one that is on ebay
#13 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 24, 2015 - 04:08 PM
I found a K181 carb, intake,and air cleaner on eBay that Im going to try buying I think.
#14 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,357 posts
Posted May 29, 2015 - 10:29 AM
Found the KV161 Engine parts list.I will upload into the kohler manual section,for Quick Mfg Co.
Here is the complete one
http://gardentractor...ine-parts-list/
Edited by drbish, May 29, 2015 - 10:33 AM.
  • Bruce Dorsi and wvbuzzmaster have said thanks
#15 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 29, 2015 - 05:50 PM
Looks like the lmv carb is standard and correct. And now i can determine proper air cleaner. Thanks.
Edited by wvbuzzmaster, May 31, 2015 - 10:11 PM.
