Rear axle seals numbers and sources?
6 replies to this topic
#1 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted May 23, 2015 - 01:22 PM
Have C-175 and need the axle seals. Part # 6449 in my papers. Any quick source?  I'm hoping for a number actually to go to local auto place to see if have or can get. Usually overnight if not in stock there. Anyone have #'s?   Otherwise, will it have to be Toro, or parts tree or similar?
  • Antoniofuse and Clintomsata have said thanks
#2 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted May 23, 2015 - 01:32 PM
There's two that are very similar , is your seal the 1-3/8'' OD or the 1-5/8'' OD?
Good chance I have a seal here instock!
  • superaben said thank you
#3 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted May 23, 2015 - 04:40 PM
The bigger seal.  Probly the 1" axles take the smaller.  Can you see what you have, how much and do you paypal?  I got sizes from Redhorse and he said can get bearing shops if you are no go. Can PM if you wish.
#4 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted May 23, 2015 - 04:52 PM
I have a cross to OEM  instock ,  at $ 8.49ea
The one I have is going to be what most bearing and seal places will cross to, the original seal is 1/2'' thick these are 1/4'' thick but will not have a performance difference. The OEm spec seals are going to be special order and would have to get those in if your looking for Genuine Toro parts.
Send me a PM if your interested, can do paypal.
#5 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted May 23, 2015 - 09:42 PM
There isn't much Brian can't cross reference.  I've tested him on that.  :smilewink:
Ben W.
  • Bolens 1000 and Sawdust have said thanks
#6 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted May 31, 2015 - 11:44 AM
Ben done me good, seals here and in. Were the 1/4" ones as noted, but fit fine. Oil back in rear, didn't see any running out, heh! Almost bet could have put two each side, but not sure any better doing that or just overkill?
  • Sawdust said thank you
#7 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted May 31, 2015 - 11:47 AM
You could double up on the seals if you wish , alot of the older farm equipment  with the old thick felt seals we generally cross to a seal and have them double up to fill in the empty space from the felt washer.
