Points for Briggs 23AFB? (Picture)
6 replies to this topic
#1 oldiron1 OFFLINE
oldiron1
  • 423 Thanks
  • 268 posts
Posted May 23, 2015 - 01:09 PM
Hi Guys,
I'm working on a 1962 Briggs model 23 AFB that needs a set of points that I can't seem to find. After an ebay search, the only ones I'm finding have a spring that these don't, so I don't believe they're the right style.
I stopped at my local Briggs dealer who pulled out the Micro Fiesch and found them discontinued through Briggs. There has to be an aftermarket source...any help is appreciated!
Thanks, Rob
  • laurarg3 and Antoniofuse have said thanks
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted May 23, 2015 - 01:17 PM
I believe those were discontinued in 2004, no aftermarket is available either!
One of the dumbest things briggs did was discontinue these IMO!
I do have some NOS full kits here if your interested , also stock the condensors
https://bolenspartsa...el-and-similar/
  • oldiron1 said thank you
#3 glgrumpy ONLINE
  • 8,616 Thanks
  • 7,923 posts
Posted May 23, 2015 - 01:19 PM
I hope not discon.   I have a few of those engines just bought.  If discontinued, I would bet there is a NEW style set that works in it's place??  Might check on that. I know the push rod seal and other things changed over years.
#4 oldiron1 OFFLINE
oldiron1
  • 423 Thanks
  • 268 posts
Posted May 23, 2015 - 02:16 PM
I was afraid you were going to say that. I don't understand Briggs thinking there nor understand why nobody is reproducing them as it has to be a pretty commonly used set of points.
What do you need for a NOS set and condensor?
Thanks, Rob
  • superaben said thank you
#5 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted May 23, 2015 - 02:22 PM
Condenser Runs $ 15.05
Send me a PM if your interested
#6 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted May 23, 2015 - 09:44 PM
:D
Nobody is reproducing them, but I am working on it.    It will be a little while before it happens, though.
Ben W.
  • Bolens 1000 said thank you
#7 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted May 24, 2015 - 08:08 AM
Rotary supplied aftermarket replacements years ago:
B&S # 292021 points or B&S # 291371 points = Rotary # BR14
B&S # 291369 condenser = Rotary # BR502
Perhaps some of these are floating around, or maybe a Rotary dealer could question Rotary.
