mower greasing
4 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 22, 2015 - 07:44 PM
so the engineers took off early when they designed my 42 in deck ( simplicity .. I think..its red anyway but it might be for my 712h )
 well they forgot my grease zerks . I am confident one of you helpful folks have a solution . also having a heck of a time getting the pulleys off . you guys got any tricks for these two issues .
  • laurarg3 said thank you
#2 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,534 Thanks
  • 2,290 posts
Posted May 22, 2015 - 08:10 PM
Many brands of mower decks used sealed ball bearings, so a grease fitting would serve no purpose.
  • alec and chieffan have said thanks
#3 tater195 OFFLINE
tater195
  • 1,639 Thanks
  • 1,108 posts
Posted May 22, 2015 - 09:00 PM
I have seen bearings in non greaseable quills with the inner seals removed. Not sure if they were OEM. There are good places to drill and tap for zerks in most.
I dont mind changing bearings and usually get 3 or 4 years out of the cheap Chinese bearings.
  • alec, holdenboy1960 and chieffan have said thanks
#4 shorty ONLINE
shorty
  • 4,192 Thanks
  • 4,418 posts
Posted May 23, 2015 - 04:23 AM
My smaller rider has the sealed bearings. I ran it over 10 years before any got rough. Another thought, if you take a sealed bearing application and start lubing, it does attract debris. When I was on a mason crew, our mechanic would take the grease zerks out. The guys would pump it full of grease and then forget about it for a while. Then the sand gets in and eats the balls. We had longer life without greasing.
#5 chieffan ONLINE
  • 6,867 Thanks
  • 4,919 posts
Posted May 23, 2015 - 06:03 AM
There are a lot of things that get way over greased.  "Pump grease till you see it come out" and the seals that are designed to keep dirt out and opened up to let the crud in.  Most mower decks will run a long time if you give the spindals one stroke on a gun ever 8 - 10 hours of run time.  It take me about 2 hours to mow and I grease about every 4th time, one pump in each one.  Wheel bushing and steering links get it a little more often.
  • shorty, WHdbJD, sodisr and 1 other said thanks
