Tiller Torque
9 replies to this topic
#1 txdieseldog OFFLINE
txdieseldog
  • 56 Thanks
  • 52 posts
Posted May 22, 2015 - 09:32 AM
Have a question. Is there a manual or does any body know just by chance, the output torque of the Jac/Ford PTO at the shaft end?
  • Chopperhed said thank you
#2 txdieseldog OFFLINE
txdieseldog
  • 56 Thanks
  • 52 posts
Posted May 22, 2015 - 09:41 AM
Sorry, wondering what the final RPM is at the shaft end as well? Any wild proximity's will be remotely considered. :D However, cold, hard, facts preferred. :rocker2: Thanks in advance.
#3 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 22, 2015 - 10:04 AM
It is basically engine rpm as both pto and pto shaft pulleys are the same size.
#4 propane1 ONLINE
propane1
  • 9,442 Thanks
  • 4,383 posts
Posted May 22, 2015 - 10:20 AM
Engine rpm, what skyrydr2 said. Noel
#5 Rock farmer ONLINE
Rock farmer
  • 1,298 Thanks
  • 1,274 posts
Posted May 23, 2015 - 05:41 PM
Why do you ask? Grasshopper.
#6 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 23, 2015 - 08:11 PM
In case you care, you can basically take  the out put torque of your particular engine, Most 16 hp engines put out around 18-20 lbs/ft of torque. multiply by the PTO pulley ratio, allow a certain percentage for slippage, and you can get a rough estimate of your PTO output torque.
#7 txdieseldog OFFLINE
txdieseldog
  • 56 Thanks
  • 52 posts
Posted May 24, 2015 - 01:19 AM
Grasshopper want to convert to hydraulic motor. Got a front hydro control from ebay and was thinking of running lines to the rear not the front.
#8 Rock farmer ONLINE
Rock farmer
  • 1,298 Thanks
  • 1,274 posts
Posted May 24, 2015 - 04:26 AM
I have a Case 444 with a hydro tiller.
It's a great set up.
But, the hydrostatic trans mission on the Jacobsen will not run a tiller.
I don't think it pumps enough volume.
Joe
  • KennyP and Chopperhed have said thanks
#9 KennyP OFFLINE
  • 40,880 Thanks
  • 47,091 posts
Posted May 24, 2015 - 04:33 AM
Joe
I agree with that. Need a separate pump to run that.
#10 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 24, 2015 - 04:34 AM
The hydro only puts out 1.5 GPM at 800 psi , not nearly enough to turn a hydraulic motor at 3600 rpm and still have enough power to turn under a load.
  • Chopperhed and propane1 have said thanks
