Ford LGT165 Revival
ford engine swap lgt165 repower 1977 ford repower
101 replies to this topic
#46 TomLGT195 OFFLINE
TomLGT195
  • 4,098 Thanks
  • 2,927 posts
Posted May 29, 2015 - 06:54 PM
Are you going to touch up the white on the cover? Thanks for the dimensions and pics.
#47 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 29, 2015 - 06:56 PM
The dash has chrome silver on the letters. Best I can do is Silver here. That will take the better part of a day.
  • TomLGT195 said thank you
#48 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 30, 2015 - 06:39 AM
 I used a white paint pen for mine and it has held up wonderfully.
#49 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 30, 2015 - 08:01 AM
I'll see if a silver pen is available locally here in a bit. The FF's have Silver letters also.
#50 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 30, 2015 - 05:47 PM
No silver pen in the store, so I did what I could to dress it up some.
Then I went to work on the front axle. Got it pulled.
Some time back, Keith made this new center pin for the front axle. It was time to put it in.
I also added a grease fitting for the center pin that was left off.
Got the pin holders welded on.
The axle is back in and much tighter. I am going to forgo the secondary hydraulics at this time until I can amass more fittings and lines. Tomorrow, the engine goes back in.
  • skyrydr2, Rock farmer, Chopperhed and 1 other said thanks
#51 TomLGT195 OFFLINE
TomLGT195
  • 4,098 Thanks
  • 2,927 posts
Posted May 31, 2015 - 06:40 AM
Will you be able to get in there to add secondary hydraulics with engine back in?
  • KennyP and Chopperhed have said thanks
#52 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 31, 2015 - 06:47 AM
I'll probably have to pull it back out, but that doesn't take too long. Not much room with the engine and that 5 gallon fuel tank in there!
  • Chopperhed and TomLGT195 have said thanks
#53 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 31, 2015 - 05:31 PM
Went out this morning and got the dash put back together.
Then I went putting the engine back in. Didn't take that long and it was all buttoned down and hooked up.
Worked a while on getting things back where they belong.
The left side of the hood is now back where it should be.
Here's the back side of the hood.
Put the side panels on and got them adjusted in.
Here's a shot of the left side. Can't do the right as I can't back up far enough.
Put the tunnel cover back on.
Here's a shot of the tractor.
I got it to fire off and run good at low-mid throttle. Has an issue with more than that. I'll look into the manual on the governor setting as I am unsyure if I have that correct at the moment. Plus it's running on old gas with extra Seafoam & MMO in there.
  • skyrydr2, Chopperhed and TomLGT195 have said thanks
#54 TomLGT195 OFFLINE
TomLGT195
  • 4,098 Thanks
  • 2,927 posts
Posted May 31, 2015 - 06:13 PM
Seat looks a little uncomfortable. :smilewink:  But the rest looks awesome!  :thumbs:
#55 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 31, 2015 - 07:14 PM
Yeah, that's another issue!
#56 TomLGT195 OFFLINE
TomLGT195
  • 4,098 Thanks
  • 2,927 posts
Posted June 01, 2015 - 04:34 PM
Ken, I found this cylinder on Joe's outdoor power equipments site. It has same length closed and same stroke, looks like it should work?
out of a Ford gt85 looks like a new holland model.
tried to copy page but wouldn't let me.
Edited by TomLGT195, June 01, 2015 - 04:35 PM.
#57 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 01, 2015 - 06:39 PM
It may just work for you. How many $ are they wanting for that? I might break up my stash and sell you one!
#58 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 02, 2015 - 06:10 PM
I tried a different battery yesterday and it was too far gone. And using the big charger to crank it over fried either the solenoid or the switch as it turns over with the switch off now. After I get this job done, I'll buy a new battery for it. I have another solenoid and switch already. Just need to test things out to see what happened.
#59 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 07, 2015 - 06:10 PM
Spent some time on the Ford today! Found out the solenoid was bad. With the key off I was getting 2.5 volts to the starter through it. Changed it out and tried a small L&G battery I had sitting around. It needed the small charger on it to turn this over. Got it running again. 2 Issues! Not charging, stator is only putting out 19 volts. And can't go more than half throttle and it starts missing and spitting fuel back out the carb. Almost acts like it is flooding. I'll get the carb I had on it in the AC and see if it runs better. But I'll have to pull the engine to change the stator out.
#60 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 08, 2015 - 05:19 PM
I'll get it figured out one of these days!
  • Rock farmer said thank you
