Ford LGT165 Revival
ford engine swap lgt165 repower 1977 ford repower
101 replies to this topic
#31 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted May 28, 2015 - 08:32 AM
I looked over the Front Hydraulic Kit PDF and see that the handle (#20) can be modified to use and the link (#18) to the valve will work also.
Got some rain moving in so I brought the hood, grille & both side panels up on the front porch so I can work on polishing them if it's too wet to do anything else.
  • Chopperhed said thank you
#32 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted May 28, 2015 - 10:24 AM
I'm glad I didn't get in a rush to put the engine back in. Finding lots of things to fix and make this a much better tractor.
Does the Kohler turn clockwise when looking at the flywheel end? Can't remember at the moment! The reason I ask is the drive shaft has a 1/2" tip sticking out & I though about hooking a drill up to it to see about flushing air out of the 'new' hydraulics. Not sure if it will work, but worth a try! :smilewink:
When looking at the hydro it turns ccw ;-)
Edited by skyrydr2, May 28, 2015 - 10:25 AM.
  • KennyP and TomLGT195 have said thanks
#33 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 28, 2015 - 03:25 PM
Nice save on that one. :thumbs:
Ditto
#34 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 28, 2015 - 03:26 PM
I did it on mine to test the system prior to starting the repower.
#35 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted May 28, 2015 - 04:52 PM
Well, the second hydraulic circuit is on hold. Need fittings, no $ for them. You check out the other thread for those issues.
But I did get the hood, grille and side panels polished up some.
The one on the left is done, the right one is next.
  • Chopperhed and propane1 have said thanks
#36 propane1 ONLINE
propane1
  • 8,474 Thanks
  • 4,039 posts
Posted May 28, 2015 - 08:48 PM
Nice work, you done the right thing, to fix things up while you had the chance. Nice to have the patience. Noel
#37 FixItCharlie ONLINE
FixItCharlie
  • 518 Thanks
  • 336 posts
Posted May 28, 2015 - 09:25 PM
I had to do some repairs to my LGT 145 & found it would be easier to do with the seat pan removed. Since I have it torn down this I am also doing the repair to the part shown in my post of Interesting Wear Points. From what I found & since you already have it torn down this far you may want to check for this also.
I was really surprised to find that much dirt on the frame under the seat.
Charlie
#38 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted May 29, 2015 - 03:14 AM
Charlie
I had all the sheet metal off it not long ago for paint. It has sat since the engine blew up. I have changed out the front axle pivot pin, but it may need more attention. I have a new pin that Keith made up for me way back that may be put in this time. I've been lubing some things as I go.
#39 TomLGT195 OFFLINE
TomLGT195
  • 3,699 Thanks
  • 2,762 posts
Posted May 29, 2015 - 04:13 AM
Ken , Can you take some dimensions of the piston that does the deck lifting? I want to add one to my 125. Parts surplus has plenty to choose from just need to know what to compare it to. Thanks ,Tom
#40 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted May 29, 2015 - 05:32 AM
You mean the cylinder?  I think they are 4" stroke. I may be able to get a closed length. No way to get to the piston as I think they have welded ends.
Looking at the parts list, doesn't help much as all it says is ' CYLINDER, Hyd. Lift 2" '. I think that refers to a 2" bore with a 1" rod.
I'll get some pics of the one I plan to use at the front.
  • TomLGT195 said thank you
#41 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted May 29, 2015 - 08:11 AM
Got light rain this morning. May last most of the day. I do have the tunnel cover to fix like I did the dash.
#42 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted May 29, 2015 - 08:47 AM
Here's the lift cylinder dimensions and pics.
2" bore, 1" rod.
Rod end hole is 1/2", cyl. end hole is 3/4".
Closed length is 9.25".
Open length is 12.75".
Not sure why this stroke is 3.5", but that's the measurements.
  • Chopperhed and TomLGT195 have said thanks
#43 tiretrx OFFLINE
tiretrx
  • 2,230 Thanks
  • 1,217 posts
Posted May 29, 2015 - 09:49 AM
Great thread. Love all the pics. Really making progress and doing some nice, clean work. Stay dry!
#44 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted May 29, 2015 - 12:28 PM
That's hard to do around here! I think I'm growing webs between the toes!
#45 KennyP ONLINE
  • 37,496 Thanks
  • 45,506 posts
Posted May 29, 2015 - 05:20 PM
Between raindrops I got the tunnel cover looking much better. It is not finished as yet as I plan to add more 'bling' to it.
Here's a before pic:
And this is how it looks now:
The left side had a big chunk missing.
