what's needed to add snowblower?
4 replies to this topic
#1 bphillips921 OFFLINE
bphillips921
  • 1 posts
Posted May 21, 2015 - 12:13 AM
I inherited my grandpa's 1987 JD 318. I intend to do some restoring to it as well as purchase a snowblower for it. My question, is the JD 47 snowblower a "plug-and-play install? Or does it require some modifications? I know I need the quick attach, but do I need anything else?
#2 toppop52 OFFLINE
toppop52
  • 5,450 Thanks
  • 4,861 posts
Posted May 21, 2015 - 06:26 AM
Well, you'll need the snow blower... :D   Just kidding, couldn't help myself this morning.
#3 JDBrian OFFLINE
  • 9,634 Thanks
  • 14,156 posts
Posted May 21, 2015 - 06:40 AM
I know the 49 snow thrower is a self contained unit but I'm not sure about the 47 blower. It may need the front hitch, which you could also use for the 54 blade. There was a guide around for all the tractors and implements that showed what fit on each tractor.  Can't seem to find it in the manuals section. I'll take a look in my files and see if I have it.
  • Trav1s said thank you
#4 hdg4400 ONLINE
hdg4400
  • 286 Thanks
  • 351 posts
Posted May 21, 2015 - 09:19 AM
Check your Private Messages here at GTTalk. I have some info that might help.
Harlan
#5 streetrodchev OFFLINE
streetrodchev
  • 2 Thanks
  • 3 posts
Posted June 20, 2015 - 08:37 PM
There are two versions of the 47.  The earlier one is complete unit and the later one is just the blower and will need the hitch and front pto adapter.
