4-6-4 Tank Locomotive
25 replies to this topic
#16 KennyP ONLINE
  • 40,110 Thanks
  • 46,756 posts
Posted June 03, 2015 - 05:39 PM
great work! I could never do something like this!
  • jdcrawler and laurarg3 have said thanks
#17 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,103 Thanks
  • 1,897 posts
Posted June 13, 2015 - 01:30 PM
Thank you everyone for following along on this project and Thank you all for the nice comments that you have made.
Here is the finished locomotive.
  • Alc, wvbuzzmaster, KennyP and 5 others have said thanks
#18 rust addict OFFLINE
rust addict
  • 243 Thanks
  • 174 posts
Posted June 13, 2015 - 01:43 PM
Nice job.
  • jdcrawler said thank you
#19 UncleWillie ONLINE
  • 16,105 Thanks
  • 8,906 posts
Posted June 13, 2015 - 02:17 PM
awesome
#20 KennyP ONLINE
  • 40,110 Thanks
  • 46,756 posts
Posted June 13, 2015 - 07:11 PM
Sharp looking loco there!
#21 TomLGT195 OFFLINE
TomLGT195
  • 4,012 Thanks
  • 2,882 posts
Posted June 14, 2015 - 09:11 AM
You do amazing work on those locomotives!
#22 Gabriel OFFLINE
Gabriel
  • 1,446 Thanks
  • 1,859 posts
Posted June 15, 2015 - 11:00 PM
Nice work!
Edited by Gabriel, June 15, 2015 - 11:00 PM.
#23 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted June 18, 2015 - 08:41 AM
I need to make a piece that will fit on the floor of the cab to hide the electric motor.
So I cut the top off a plastic bottle that toothpicks came in.
Then I cut that part in half and painted it black.
This half round piece is glued on the floor of the cab to hide the motor.
Once the cab roof is attached and everything is painted, this piece won't be very noticeable.
The rear panel for the cab is also glued in place on the front of the tender.
Next is to make up the top section for the tender.
The inside of the coal bunker is lined with wax paper and a piece of wood is set inside it.
A thick layer of adhesive caulking is spread over the piece of wood.
Some "coal" is pored over it and pressed down into the adhesive.
The excess coal is cleaned off and the part is set aside so the adhesive can dry.
I'm using the "coal" that is made by Lionel.
The adhesive turns clear when it is dry.
Here is the tender with the coal bunker in place.
excellent build so far ,am really enjoying the progress of this loco build
Shane
#24 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted June 18, 2015 - 08:46 AM
job well done , job done to the taste of a true engineer
#25 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted June 18, 2015 - 08:53 AM
have you ran the locomotive & if so how does it run? ,
is it as good as you expected ?
is there any alterations or changes you would like to make to it as improvements ?
what dec of turn & assent climb can it navigate freely if known ? please
Shane
#26 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,103 Thanks
  • 1,897 posts
Posted June 18, 2015 - 04:55 PM
Shane
I haven't ran this one yet.  It got packed up and put in the trailer for our move as soon as it was finished.
I've built several different types of locomotives  over the years using this AHM 0-8-0 kit as a running gear.
These engine kits run well and when steel weights are added to the engines, they can pull quite a few cars.
  • TomLGT195 and holdenboy1960 have said thanks
