Twisting a V belt
3 replies to this topic
#1 Alc ONLINE
  • 6,912 Thanks
  • 7,473 posts
Posted May 20, 2015 - 05:26 AM
The belt I got for the DB Weed-Cutter gets a 90* twist . It  came notched . Can that be used in this application  ?
#2 KennyP ONLINE
  • 38,498 Thanks
  • 45,981 posts
Posted May 20, 2015 - 05:53 AM
I would think it would make it harder to stay on, but that's me.
#3 grattone OFFLINE
grattone
  • 309 Thanks
  • 220 posts
Posted May 20, 2015 - 07:13 AM
I'm not and expert on belts but that cured a problem I had with a belt coming off. Makes it more flexible I guess.
Good luck Gratton
#4 chieffan ONLINE
  • 10,201 Thanks
  • 6,659 posts
Posted May 20, 2015 - 07:34 AM
Cog belts are more flexible.  You may have to run it a bit tighter but it should work just fine.
When the two sides start to contact each other at the twist is when problems occur with cog belts.   Good luck.
  • Alc, KennyP, Cat385B and 1 other said thanks
