Hydro or Manual? Which do you prefer?
20 replies to this topic
#16 TUDOR OFFLINE
TUDOR
  • 544 Thanks
  • 497 posts
Posted May 20, 2015 - 04:19 PM
Always been fond of manuals. To me they just seem to pull harder.
They do, when pulling at WOT. The problem is that unlike at the pulling track where the tractor starts with pulling a light load that gets progressively heavier, at home, most situations require maximum pull to start the load moving, and then it gets progressively easier. That is where a hydro will beat on a manual transmission. No clutch to slip to keep torque up and horsepower (and therefore speed) down.
#17 toppop52 OFFLINE
toppop52
  • 4,588 Thanks
  • 4,294 posts
Posted May 20, 2015 - 08:07 PM
Why on earth would you think hydro has to be run wide open?! My MF 1855 with Johnson loader, was almost never over 1500-1800 RPM when moving dirt, stone air pushing 3"-4" trees over.
#18 TUDOR OFFLINE
TUDOR
  • 544 Thanks
  • 497 posts
Posted May 20, 2015 - 11:54 PM
Entry level hydros in LT's tend to make high pressure, and therefore heat, when pushed as in climbing slopes. The Tuff Torq K46 can only deliver 2.73 hp and 131 or 171 ft-lb of torque to the rear axle, depending on the final drive ratio.
It's a bit different with the heavier hydros.The Sundstrand in your 1855 is capable of delivering 11 hp to the rear wheels at 1500 psi. The axle torque in low range is almost 800 ft -lb at that pressure and it takes a lot of ballast to keep the tires hooked to the ground.
Basically, you have a bit more than twice the tractor weight but 4 times the hydro, and you haven't even begun to tap the hydros' reserve at 1500 psi. You will break the Peerless well before you hit max torque capability.
Edited by TUDOR, May 21, 2015 - 12:06 AM.
  • toppop52 said thank you
#19 The Fife Plooman OFFLINE
The Fife Plooman
  • 1,444 Thanks
  • 278 posts
Posted May 21, 2015 - 01:54 AM
Hi all
All my horti tractors are old fashioned gear boxes would not swap them they are  Gutbrod 1032  s
The mower I use to cut the grass on the caravan park is a 4 wheel drive Stiga mower and is hydraulic drive  to go forward you press forward with your toe to go backwards you press down with your heel it takes 20 hours to cut the grass if it was a gear box it would mean a lot of gear changes
  • MH81, BNK and holdenboy1960 have said thanks
#20 toppop52 OFFLINE
toppop52
  • 4,588 Thanks
  • 4,294 posts
Posted May 21, 2015 - 06:23 AM
That makes sense, I know I never Revved that one much and it did a lot of work.
#21 holdenboy1960 OFFLINE
holdenboy1960
  • 1,747 Thanks
  • 939 posts
Posted May 23, 2015 - 06:09 AM
i think hydro for grass cutting , i got MTD , JD & Toro love all 3 for grass work , but prefer the ole school gears for pulling & such
  • BNK said thank you
