sears roto spader 785.297252 273
7 replies to this topic
#1 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted May 19, 2015 - 09:50 AM
Hi guys !
I am usually on the ford/Jac tractor forum but I recently picked up a roto spader.  The   tines will engage only when they are out of the dirt.  They will then turn when engaging the dirt.  It seems as though they should turn starting with the tines on the ground.  Seems a little weak??  Any ideas?? I do not have a parts schematic or a manual??  Thanks much!! ( ps tecumseh engine, 3-5 hp and gear drive) Picture to follow. 1976 model I think
Mike
Genoa,IL
66 jacobsen  chief 1000
sears roto spader
Edited by Mike125s, May 19, 2015 - 09:51 AM.
#2 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted May 19, 2015 - 09:59 AM
Hi guys !
Mike
Genoa,IL
sears roto spader
Link to photo
file:///C:/Users/Mike%20Carpino/Downloads/FullSizeRender.jpg
#3 KennyP ONLINE
  • 36,514 Thanks
  • 44,966 posts
Posted May 19, 2015 - 10:21 AM
I haven't found anything on this. The 785 is an Atlas/General Power product. Your pic link isn't working!
  • Mike125s said thank you
#4 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted May 19, 2015 - 10:24 AM
Mike, I also have trouble with the pic,
Try this link for help:
http://gardentractor...file-uploading/
If you still have trouble, let us know.
As for it not turning, is it belt slippage? If so, the tightener a are adjustable on most rotospaders.
  • boyscout862 and Mike125s have said thanks
#5 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted May 19, 2015 - 05:05 PM
I was trying to go apple to windows. try this. thx guys!!
Edited by Mike125s, May 19, 2015 - 05:08 PM.
#6 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted May 19, 2015 - 07:20 PM
some of the ose tiller used a cone clutch under the motor, if so I would guess that where the trouble is.
#7 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted May 19, 2015 - 09:47 PM
Is that clutch adjustable?? I will separate the motor from the gearbox next. thank you
mike
  • Lauber1 said thank you
#8 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted May 20, 2015 - 05:10 PM
not sure how that adjusting works, never had to adjust one of mine, but then again they are the older type units than yours.
