Help me I'm not good at this!
23 replies to this topic
#16 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 19, 2015 - 12:09 PM
I did tighten the shaft where it couples to the motor. I'll try to upload video.
  • Antoniofuse said thank you
#17 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 19, 2015 - 12:13 PM
The intake valve spring sits on the nut. The nut is tight to the shaft but the whole thing spins while goin up and down
#18 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 19, 2015 - 12:14 PM
I tried to post a pic w that last caption but o don't think it worked
#19 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 19, 2015 - 12:21 PM
#20 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 19, 2015 - 12:27 PM
#21 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 20, 2015 - 04:41 AM
It could be that something is worn, causing the noise. If your motor mounts are cracked or broken that can cause excessive movement in the engine and the driveshaft. The noise could be something on the engine or chassis vibrating.  Check the rear shaft coupler at the hydro input. That coupler can wear causing the input shaft to get worn. That 316 looks to be in very good condition!
  • HDWildBill and Bassethound have said thanks
#22 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 21, 2015 - 12:22 PM
The motor shakes pretty bad. The pin in the carb is split alittle right at the point. Like a small brass splinter? Is that bad?
#23 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 23, 2015 - 10:49 AM
Okay noticed a busted rear motor mount. I'm gonna fix that and see where I stand w noise.
  • Oldford said thank you
#24 JBRamsey OFFLINE
JBRamsey
  • 1,567 Thanks
  • 878 posts
Posted May 23, 2015 - 11:39 AM
That's it. Troubleshoot first, then buy parts. It can save you a lot of money. Trouble shooting. Is essentially free. It's just your time.
  • Oldford and holdenboy1960 have said thanks
