Help me I'm not good at this!
23 replies to this topic
#1 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 18, 2015 - 11:42 AM
Hello I'm new to this forum. I have a deere 316 Kohler k341 16 hp. Fires up now that I rebuilt the carb but only runs till it warms up. As soon as she hits temp it sounds like she's knocking or taping before she just dies. Won't start till she cooks off. Pulled the head and there's some carbon build up but the valves aren't bent. Is it possible part of the ignition system like the cool is showing that it's going out when it heats up? I don't want to just start buying parts blindly....help
  • tinbender7, holdenboy1960 and laurarg3 have said thanks
#2 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted May 18, 2015 - 11:58 AM
That is a classic symptom of a bad coil that I have seen in several applications. When they start to get weak they will sometimes die at high temps.
You could check the spark when its cold and then warm it up until it dies and see if the spark gets weaker or goes away.
Edited by cpg, May 18, 2015 - 12:01 PM.
  • tinbender7, boyscout862, WNYTractorTinkerer and 1 other said thanks
#3 MH81 OFFLINE
Posted May 18, 2015 - 12:06 PM
I agree, also could be a condenser breaking down.
Oh, and :welcome: to GTTalk, thanks for joining.
  • tinbender7, boyscout862 and holdenboy1960 have said thanks
#4 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 18, 2015 - 12:31 PM
Welcome aboard.  Use a spark tester and when it dies see if you are getting spark.  If not start tracing back in the system until you find the problem.
#5 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 18, 2015 - 12:36 PM
I have spark when she's cold. It bit me cause the insulation is wearing off. I'm gonna but condenser and coil on the way home from work. Also...... When I take my valve cover off to check my valve gap, I set it then tighten the nut to the"shaft" I don't know the right words sorry. Once it's set and tight does the whole thing spin free under the valve springs?
  • tinbender7 and holdenboy1960 have said thanks
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 18, 2015 - 12:51 PM
I'd check your points and set them to .020 gap. If they are pitted or out of adjustment it will give you all kinds of grief. They can move if you don't get the adjustment screw tightened down enough. Also, check all the wiring connections between the points and the ignition switch.
   Follow the instructions in the Kohler K service manual to adjust the valves. If you don't have the manual there should be one in our manuals section.
  • trowel, tinbender7, HDWildBill and 2 others have said thanks
#7 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 18, 2015 - 01:08 PM
Do I need to removed the engine to do my points? The flywheel is inline with the driveshaft
#8 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 18, 2015 - 01:55 PM
Also if the coil and or condenser is pooping the bed, would that make a tapping or knocking noise?
#9 propane1 ONLINE
propane1
  • 8,726 Thanks
  • 4,132 posts
Posted May 18, 2015 - 02:47 PM
Sticking valves when hot maybe.  Noel
#10 HANKG OFFLINE
HANKG
  • 6,323 Thanks
  • 3,427 posts
Posted May 18, 2015 - 03:59 PM
Welcome aboard good advise all above
#11 TomLGT195 OFFLINE
TomLGT195
  • 3,833 Thanks
  • 2,816 posts
Posted May 18, 2015 - 05:05 PM
:welcometogttalk:   :wewantpics:  please.  :D
#12 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Welcome to GTT. As you can see, we have a friendly and helpful site. Enjoy! Good Luck, Rick
As far as the engine, use the troubleshooting guide in the manual and take it a step at a time.
Edited by boyscout862, May 18, 2015 - 05:08 PM.
  • HDWildBill and holdenboy1960 have said thanks
#13 Bassethound OFFLINE
Bassethound
  • 16 Thanks
  • 25 posts
Posted May 19, 2015 - 10:38 AM
Ignition coil condenser spark plug and the wire replaced. Engine starts and runs. Doesn't die when warm but there is a knocking mostly at WOT but a few here and there at idle. Now that it will idle I can listen to it. I don't think its a valve tap. If I buy the rebuild kit and the cylinder is not warn.... Do I need to bore it and get bigger piston or can I just put brand new original size in? Thanks the advise by the way.
  • boyscout862 and holdenboy1960 have said thanks
#14 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 19, 2015 - 11:15 AM
Can you take a video of it running and let us here the noise you are hearing?  We could better advise you if we could hear exactly what the knock is.
#15 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted May 19, 2015 - 11:50 AM
If it has the drive shaft that connects right to the flywheel also check to make sure there is nothing loose or worn in the drive line that could be knocking before just pulling the engine apart.
